Hello,
Wanted to hear input from members that have Erics new Nismo poly bumper. Fitment good? Good as oem? Major gaps? etc. Please provide pictures if you have Erics poly nismo bumper.
I am considering Erics bumper and wanted some help from my fellow G members.
Thanks guys.
Floyd
Thanks guys.
Floyd
there was nothing wrong with the old nismo poly bumper (no gaps) except for not being able to use the oem plastic cover under the car but the new nismo bumper fixed that issue.
The gaps vary from car to car, but in terms of improvements Im guessing he smoothed out some spots on the poly to prevent paint cracking. Just probably prepped it better.
Higher Pressure is used now a lot less pin holes and easier on the bodyshop thats working on it.. thicker mix of poly is used - still flexible same mesh mounting points same grill mounting points.. Cleaned up the side marker area its not more sharply cut with less imperfections. most of all it now attaches to the under body engine cover
also added something that'll hug the core support under the headlamp to close that gap all the way under the headlamp
added some pixs for u
