black grill advice.
Old Nov 20, 2009 | 01:03 AM
  #166
biggz786786's Avatar
wow this thread is old haha,
obsidian black grille ftw!
Old Nov 26, 2009 | 02:51 PM
  #167
stinkytofu89's Avatar
very nice! now i just need to find out how to remove the grill from the bumper to do mine..
Old Dec 1, 2009 | 03:07 PM
  #168
seagrasser's Avatar
^ it's on page 3 of this thread
Old Dec 9, 2009 | 08:23 PM
  #169
agui35's Avatar
Originally Posted by patman530
I would do flat black, and easy on the clear coat
what kind of paint did you use(spray can?) where do I buy it
Old Dec 16, 2009 | 06:42 PM
  #170
acurael's Avatar
has anyone got it paint matched? I was thinking of getting a bodyshop to do it for me so it matches perfectly. I have a black 06 coupe
Old Dec 16, 2009 | 08:15 PM
  #171
ur in luck, i got mine painted obsidian black
Old Dec 16, 2009 | 09:17 PM
  #172
NaiveRapture's Avatar
ooooooooh and a Greddy front (methinks) *swoons*
Old Dec 16, 2009 | 09:29 PM
  #173
^actually its a kurumaZ
Old Dec 16, 2009 | 09:54 PM
  #174
Ohmyjesus Yeah that's what I meant bwahahahha
Old Feb 25, 2010 | 09:56 PM
  #175
lexx's Avatar
Sorry to bring this thread back to life but want to paint grill black. Going with dupli-color black primer, not sure if i should go dupli-color gloss black or dupli-color universal black. Any thoughts? But either way do you always need the clear coat step?
Thanks!
Old Feb 25, 2010 | 10:12 PM
  #176
^just look through the pages to find out if you want gloss or not, as for clear coat, you should use it if you want it to stay on for a while
Old Feb 25, 2010 | 10:27 PM
  #177
lexx's Avatar
Thanks for the info on clear coat!
Old Feb 25, 2010 | 10:30 PM
  #178
lexx's Avatar
Originally Posted by twalls
^yupper, I did gloss black.. It's the EXACT same procedure, just use gloss black (Universal Black- if you're using duplicolor).. Everything else is the same.. I really advise getting Duplicolor paint (found at Autozone).. Save yourself the time of doing it over again (like I did).. Goes on evenly, and the nozzle makes a HUGE difference.. Take your time and use multiple coats. Duplicolor also aids in not cracking under heat and cold..
This is the reason I couldn't decide between universal or gloss. Dupli has both universal and gloss, twalls said he went gloss but used universal. So I wasn't sure if the univeral was a type of gloss.
Old Mar 1, 2010 | 06:42 PM
  #179
acurael's Avatar
Question. Do you guys paint the inner portion of the Mt. Fuji symbol? like the area that goes into the grill but u can still see a bit if you are close enough. Its hard for me to tell on the above pics if its actually painted or just a reflection.
Debating whether to get it paint matched or go with another grill
Old Mar 1, 2010 | 07:16 PM
  #180
no i didn't paint the back portion of the mount fuji emblem, but i will be, i like it paint matched, looks really clean imo
