Messed up Bumper!!!! :(
Old Mar 1, 2009 | 11:39 AM
marki24's Avatar
Ok so I messed up my bumper, i hit a huge rock while exiting someones driveway. There was no light and it was completely dark, and I guess my headlights and my vision was not enough for me to see it. So anyways the bumper is messed up on the passengers side and my washer fluid leaked out. Does anyone know if the washer fluid container has any drainage on the bottle where it could have opened an opening and caused it to drain. The bumper is also intendend on the bottom and it has a few good amounts of scratches. Now my other question is does anyone have instructions on how to remove my bumper. I am planning on fixing this myself as I believe if i take it to a shop this will cost me more than 1,000. Does anyone know how to remove this bumper. I can post pictures later if anyone is interest in seeing the damage. Thanks for the help in advance.
Old Mar 1, 2009 | 11:44 AM
NaiveRapture's Avatar
I think you'll definitely get some better responses if you get pictures, and if you do a search you should find a DIY or a How To about removing your bumper. Do you have a coupe or sedan??
Old Mar 1, 2009 | 11:53 AM
marki24's Avatar
Its a 2008 g35xs sedan.
Old Mar 1, 2009 | 03:17 PM
marki24's Avatar
anyone???
Old Mar 2, 2009 | 12:08 AM
miltoda's Avatar
THere are instruction on here for removing 1st gen bumpers. A quick search should get you started. I would assume the 2nd gen are similar. I believe there is a drain on the bottom of the washer fluid tank so that you can drain it for any service related procedure. You probably just put enought stress on it to hopefully just push the plug out and not crack the tank. THat's the least of you worries though as new bumper cover is probably going to run 400 + paint.
Picture Share
Feb 4, 2018 12:41 PM
dseet
Oct 11, 2015 12:40 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jyounya
Sep 12, 2015 04:03 PM
