Power Window Issues
Old Apr 1, 2009 | 12:20 PM
acemallone's Avatar
Power Window Issues
Every time I use the automatic window closing switch, it closes, then quickly reopens about 3-5 inchs. How do I solve this?
Old Apr 1, 2009 | 12:22 PM
Middleeastg's Avatar
is the door closed fully?
Old Apr 1, 2009 | 12:26 PM
TheDude's Avatar
I think the window motor needs to be reset, I believe there is a thread here about it somewhere, let me see if I can find it.
Old Apr 1, 2009 | 12:29 PM
TheDude's Avatar
http://www.350z-tech.com/zwiki/Servi...eset_Procedure
Old Apr 1, 2009 | 01:10 PM
yourdoinitwrong's Avatar
Hopefully the reset works for you. Mine started doing this and then a week later it gave up the ghost. I ended up having the whole window motor replaced.
Old Apr 1, 2009 | 01:26 PM
gary c's Avatar
Nissan Window Motor Failure....?
The window motors that Nissan uses leave a lot to be desired. My neighboor
has replaced 3 in his Z, I think he plays with it....
Gary
Old Apr 1, 2009 | 04:50 PM
twalls's Avatar
CLUB MODERATOR
from what I've read on other threads, the nissan motor was created w/out a vent and therefore it fills w/ carbon filings that clog the motor.. the only way to fix it is to disassemble the motor, clean it, regrease it and it'll work fine.. If you just buy another one, it'll do the same thing eventually..
leo38cheng
Nov 12, 2015 06:49 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
