IONIC gialla replica grill users!! NEED YOUR HELP!
hey guys!!,I installed my gialla replica grill from Ionic and rand with double sided tap on bottom and was making wind whistling noise when i drive, so following Jose's recommendation, I took off all the double sided tapes, and ran the grill without anything except obviously the tabs on the top.
guess what, its still making wind whistling noise.. I have 350gt emblem on the grill.. but i dont think thats the cause of the whistling noise.. help me out~!! even took out my arc panel..
Should I put double sided tape back on the bottom of the grill, but this time, make it air tight on all bottom and sides?
Need suggestions..Im tired of driving around in my G sounding like bub rub and lil sis from Oakland..WHISTLES GO WHOOO~~
Interesting. I have never noticed a whistle with mine at all. I will have to listen more intently just to make sure though. I never used tape per a few recommendations and only the tabs hold it in place. I don't run an emblem anymore but when I did I still never noticed any whistle so that's news to me. Hope you can get it ironed out.
I have come to the conclusion that I don't have a whistle. I have been paying close attention, both windows open and closed and still don't hear a thing regardless of speed (20 - 80mph).
Can you take a vid or something of the whistle? I am really curious how loud it is.
I will try to lower my hood latch to make the gap between the grill and hood tight..when i adjust 3 bolts, am i making them loose? if then, do i need to put some type of washers between the existing nut and the bolt head to make it tight? because if im loosening them, I sure there will be some sort of rattling going on..no?
