Air leak on drivers side window
Old May 14, 2009 | 12:13 PM
parhamm1's Avatar
no problem! Let me know how it goes and I'll do the same.
Old May 14, 2009 | 01:51 PM
g35rcr's Avatar
if you apply tire dressing to the weather sealing each time you clean your car it wont dry out
Old May 14, 2009 | 03:01 PM
parhamm1's Avatar
^^^ This is more good advice. Cheers
Old May 14, 2009 | 06:15 PM
riflydon's Avatar
Originally Posted by parhamm1
dirty, I've tried that already. Does not work at all. I even tried adding some foam/rubber behind the existing weather strip and it just makes the whistle worse...
I went to the stealership a while back and they told me the weather stripping was $121 and with labor the total was going to be $225! So, I tried to macguyver (sp?) it doing all those things with other crap and it just all made the situation worse. Let me know if you come up with any other fix.
Like I said before I'll be going to buy the part from the stealer and just replacing the whole thing unless there are any other remedies...
What is the weather stripping? is that the black plastic stuff besides the window? My car's passenger side air leak, god damn annoying... I really want to fix it. And the windows does move when i closed the door, is that mean the height of the windows doesn't need to adjust?
Old May 14, 2009 | 06:31 PM
BloodlineG's Avatar
yup mines doing it too just noticed a couple days ago funny you guys start a thread about it. yea its new weather stripping needed. good thing i get 20% off parts at all dealerships and labor cut.
Old May 15, 2009 | 10:46 AM
parhamm1's Avatar
20% off? Employee discount? What? Help?
Old May 15, 2009 | 10:52 AM
parhamm1's Avatar
You don't need to adjust your windows. Your weather stripping is going bad. Same as mine. And yes, that black stuff around the door frame is the weather stripping. Be ready to pay $120+ for a piece of rubber from the stealer for just the part.... I'll be doing the install myself either over the weekend or early next week and I'll let you know how it goes. I don't know if enough people are having this issue to put together a DIY. I'll take some pictures regardless so people can have them if need be.
Old May 15, 2009 | 05:59 PM
VVFive's Avatar
I had the exact same problem. Beleive me, i know exactly the pain anyone havign the same problem would have.......Infact mine was on the Driver side and it was so messed up that whenever I drive it through an automatic car wash, I had to take off my shirt and cover the gaps to stop the water from coming in........
I took it to the Infiniti Delearship and they took care off it by putting in additional weather strips and the best part they did it free of charge......
Old May 15, 2009 | 11:07 PM
parhamm1's Avatar
Haha, I do exactly the same thing^^^. It's absolutely terrible. Dealer fixed this for you for nothing? I assume you were still under warranty?
Old May 16, 2009 | 11:44 AM
VVFive's Avatar
Aye Aye Sir.... forgot to mention that I was still under Warranty......
Old May 17, 2009 | 05:50 AM
riflydon's Avatar
yea yea, so looking forward
Old May 17, 2009 | 09:06 AM
cruzmisl's Avatar
I think BMW sells some kind of rubber conditioner for these kinds of seals, because their coupes are the same way. I had this problem on my e36, but only after it was 10 years old.
I wouldn't put tire dressing on it. Most of that stuff is just silicone, and that **** is nasty if it touches the windows.
Old May 17, 2009 | 09:10 AM
cruzmisl's Avatar
A quick search says a product such as Wurth Rubber Conditioner (or any other rubber protection product WITHOUT SILICON) will work best.
http://www.superiorcarcare.net/wurucagelst.html
Old May 18, 2009 | 05:35 AM
EatRiceBeNice's Avatar
Does anyone know which of these are the weather stip part?
Does anyone know which of these are the weather strip part?
I would think it's this one: http://www.infinitipartsusa.com/part...layCatalogid=0
or would it be this? http://www.infinitipartsusa.com/part...layCatalogid=0
Old May 18, 2009 | 12:17 PM
  #30
IrockAG35's Avatar
Ohio G Club moderator
you can always call the dealer tell them your problem and theyll send you to parts for the part number
