Is there a problem applying tint material over the dots on the rear glass?
Old Aug 17, 2009 | 12:10 AM
haagen_dazs's Avatar
I read and heard from a friend that there may be some problems when applying the tint over those black dots on the top band of the rear glass panel...
could someone explain what the problems could be and how do good tint companies go about overcoming this problem?
many thanks in advance.
Old Aug 17, 2009 | 12:19 AM
redlude97's Avatar
the dots are ceramic and tint doesn't stick to them well, it leaves a light ring around them that is pretty noticeable. A good tint shop should be able to get them to stick, either through sanding or the use of an adhesive. Don't settle for spraypaint or vinyl
Old Aug 17, 2009 | 12:23 AM
thanks redlude.
so it seems the good shops will sand it or use glue??
i read about vinyl but its weird from the inside. there is a black bar layer on the top of the rear glass...
why do car manufacturers but those ceramic dots on in the first place?
can those dots be removed?
Old Aug 17, 2009 | 06:52 PM
DrewTheSuit's Avatar
sand before tinting, i regret not doing it the first time around
Old Aug 18, 2009 | 10:39 PM
Beebo's Avatar
^+1
Old Aug 20, 2009 | 10:51 PM
madmike1029's Avatar
Does the tint shop do this or is this something you would/should do yourself?
Old Aug 27, 2009 | 10:18 PM
a good tint shop should do it
Old Aug 27, 2009 | 10:20 PM
Beebo's Avatar
Yeah a good shop can do it but you have those few shops say its a bad idea and try and talk you out of it but dont listen to them
Old Aug 31, 2009 | 10:03 PM
Yup, the place I am talking to with currently seems to be in that category. sucks cause they are the only licensed llumar dealer less than 50+ miles away lol.. This is the response I got asking how they handle ceramic dots on cars like my friend's 328 and my g35:
Hi,
We usually install vinyl over dots on the top of the back windows.
The way we do it is that we tint up to the dots and dots are covered by high
performance vinyl.
Your G35 usually does not need it because film sticks very well to them.
On 328 I would recommend doing it.
Side windows come out fine without messing with dots.
We have samples of all films we carry.
Thank You
Nino
atk08
Jul 30, 2015 03:12 PM
Soumilg
Jul 18, 2015 12:33 PM
newbdriver01
Jul 15, 2015 06:10 PM
