props to Rock-Auto, window motor replacement
Old Sep 2, 2009 | 07:58 AM
idrive_MD's Avatar
So I replaced my window motor the other day, sourced the part from Rock Auto as non of my local big parts chain stores could source the part for some reason. Certainly worth the savings by doing it on my own, I was a little surprised by all of the bolts used on the second internal door panel, but no biggy. I had nice weather at home so I actually did this in my parking spot.
...and now by posting this I suspect there are at least 10 people experiencing window failures today!
Old Sep 2, 2009 | 01:17 PM
dollyg35's Avatar
yes... window motor take a poop on my last week
Old Sep 2, 2009 | 05:11 PM
DHCrocks's Avatar
good luck with that rockauto remufactured window motor. I just replaced mine a few weeks ago. Both sides and the passenger side window motor failed on the same day I put it in. I ended up just getting the passenger motor from the dealer, sure it was more expensive but at least it works. Just a little history I've replaced window motors on several cars in the past and the remanufactured ones have only lasted a year on a couple of occasions. I think I'll just stick with new motors from now on.
Old Sep 2, 2009 | 07:42 PM
dollyg35's Avatar
By chance do you try to clean the window motor? I found a DIY on this site https://g35driver.com/forums/body-in...l-removal.html I'm going to try to clean the motor before I buy another motor. Well my friend hope you run into better luck.
Old Sep 2, 2009 | 07:50 PM
DHCrocks's Avatar
cleaning will work temporarily, I've cleaned mine in the past lasts maybe 6 months? but I use the windows several times every day. and it's a pain so i just gave in and replaced them.
Old Sep 2, 2009 | 09:23 PM
Brwn5454's Avatar
Cleaned mine and its working perfectly.
Hasanbaloch
Feb 29, 2024 08:45 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
mjfenix
Jul 17, 2015 02:07 PM
