clearance lights install
Old Sep 5, 2004 | 02:32 PM
shawnmalhotra's Avatar
hey guys, can someone show me the way to take out my clearance lights (with pics)?? cuz do i really have to take the tire out in order to take the plastic cover out?? i was able to get the 3 plastic tabs out.. but i couldnt get the one screw next to the tire.. the tire was in the way.. anyone can help me?? i really hate that stock clearance light lol..
Old Sep 5, 2004 | 05:44 PM
WoRLdSYoURsG35's Avatar
G SQUAD
Re: clearance lights install
try jacking the car up and turning the tire in. thats how i got it. it shud give you enough room to work with
03.5 Black On Beige/ Navi/ PopCharger/ Z-Tube/ PIAA/
Old Sep 5, 2004 | 08:17 PM
GR8TG35's Avatar
You need to jack the car up some, but the tire doesn't have to come off the ground. It also helps if you turn the wheel in
look here this will give you a little insight into whats necessary.....
make sure to remove the two screws on the top of the wheel well
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Sep 12, 2004 | 03:42 AM
Kyosho's Avatar
just changed my clearance and sidemarker bulbs today
the good thing is that the blue is noticeable without the headlights, but with them on it appears more as a dull white/purple
Old Sep 12, 2004 | 02:17 PM
richie's Avatar
I think im the only retard here....has anyone dropped the clearance bulb into the headlight housing..??? i was putting on my amber clearnace bulbs yesterday...i put it in its' socket...but when i turned on the lights to test it out....it didnt turn on....so I take it out...but this time when I take it out the bulb gets detached from the black thing...and basically falls into the headlight assembly.... doh.... I wonder where it's sitting right now??? well, i hope it doesnt cause any problems later
'04 Laser Red 6MT
piaas all around (clearance, reverse, dome, door, and fogs)
AVH-P7500DVD / Basslink
Z tube / K&N / Greddy Evo 2
Hotchkis Sways
Side Blinker Mod
Old Sep 12, 2004 | 06:18 PM
Kyosho's Avatar
youre not the only one =\
my friend dropped one into mine on my install and i just dropped another into shawn's. aftermarket bulbs just dont seem to fit the wedge socket tight enough and it takes some wiggling to get the bulb into the housing. i tried tapping around on my fender and i could hear the bulb rattling around inside but there was just absolutely no way to get to it unless i took out the entire headlight housing.
Old Sep 12, 2004 | 07:23 PM
kyosho dropped my clearance bulb!! LOL its all good.. thanks for switching my lights doe jean =P
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
Ashton35
Jul 22, 2015 09:19 PM
Ashton35
Jul 17, 2015 10:11 AM
attarday
Jul 15, 2015 04:03 PM
