Help, cant undo wire harness
Old May 5, 2010 | 12:27 PM
JLAWG35's Avatar
I'm trying to remove the center console/shift boot top on my 07 5at. I cannot unclip the large wire harness to save my life, i've tried everythign and am afraid to break it, can anyone help?
Old May 5, 2010 | 01:02 PM
35Alive's Avatar
I assume your refering to that large white one attached to the shift surround? If so, you're right, that sucker is big and in there good (thats what she said). Little trick is to mash that white tab in with a screwdriver (releasing mechanism) while at the same time using another small screwdriver to wedge in and twist to pry the two apart. Takes patience and sum skill but not that hard.
Old May 5, 2010 | 01:17 PM
JLAWG35's Avatar
mash the tab directly in or up and in, down and in?
Old May 5, 2010 | 01:52 PM
35Alive's Avatar
Oh man its been a while, I wanna say just strait in and you'll be fine, its not a complicated mechanism, just a plastic tab keeping them together. You can press the tab in and shimmy the plug apart a little at a time with the twisting screwdriver technique, switching sides to get more leverage if need be. Be patient, that's one of the tougher plugs.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
prinny
Nov 22, 2015 11:07 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
