Help with window troubles please
Old May 30, 2010 | 11:57 AM
DigitalMaxz's Avatar
hey guys i drive an 06 Coupe,
my window has been acting up, go up too much or etc.. my motor has no problems but just didnt know the limit where it should stop moving up or down (so i think it just needed the limit reset). When i started to take the door panel apart, my window was closed and up all the way with and a little down (automatically). When i took the plastic door panel off (not the metal panel), i loosened the screws holding the window motor.. (i forgot), and i attempted to put my windows down, so then it made this cranking noise and it stopped moving..so i stopped trying to move it, i went ahead and cleaned the motor anyway. I left the motor on, but took out the cover and cleaned the inside.. the copper is clean and shiny, the part where the turbine sat in went from black to white.. i put everything back in and now my window doesnt work at all.. any suggestions? maybe the contact points? did i mess up the motor somehow when i tried to put it down when the motor wasn't tightly screwed in? or could it be the regulators?
i'm going to take it apart today, and actually remove, check and remount the motor.. what should i be aware of and checkin to make sure it works?
thanks
Old May 31, 2010 | 12:44 PM
so yesterday I took it apart again.. found out that the turbine won't move.. the regulators are fine (the square hole where the motor feeds into the regulator) since i was able to manually put the window up by turning the turbine myself. So, the turbine just won't move. My speculation is that i blew a fuse somewhere when I tried to pull the window down halfway when taking apart the metal panel on my door.. could that be a problem? I'm beginning to think it's an electrical issue.. my motor wasn't sluggish when it was working 3 days ago and just needed a reset. I have no clue where to find the fuse or anything.. :\
Can someone tell me more about the electrical fuses/connections for the window motor? and also, if there's a specific way I should put the motor back together
Dallsinghjr1
Sep 17, 2023 11:25 AM
dseet
Oct 11, 2015 12:40 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
