steering wheel controls
Old Feb 10, 2011 | 06:44 PM
jwin100's Avatar
how do i get the steering wheel controls of my 05 coupe?
Old Feb 11, 2011 | 01:39 PM
TannerG's Avatar
I don't know what you are asking. Do you want to take the controls off or buy new ones?
Old Feb 11, 2011 | 04:15 PM
jwin100's Avatar
I need to get them off the steering wheel so I can change out the LEDs.
Old Feb 13, 2011 | 02:23 AM
Enigmatic42's Avatar
there are lights in the steering wheel?!?!?!?
Old Feb 13, 2011 | 02:45 AM
G35Papa's Avatar
You have to remove the steering wheel
After you remove the steering wheel, you have to remove the back cover from it. Remove the two screws that old the airbag cage/frame inside the steering wheel. After that comes out, there are 3 screws that hold hte back cover on. From there, there are two screws per switch/side, then they come right up and out.
Old Feb 13, 2011 | 02:54 AM
Sounds easy but how do you remove the steering wheel?
Old Feb 13, 2011 | 04:42 PM
jwin100's Avatar
i know you have to remove the bottom plastic piece and then you can get to the steering wheel, but how do you get the steering wheel off? and will i have to be carfeul of the airbag letting loose at all?
Old Feb 13, 2011 | 05:50 PM
also anyone know what lights go in it? and where to order?
Old Feb 13, 2011 | 06:43 PM
jwin100's Avatar
im pretty sure that they are 0805 smd LEDs and all you have to do is solder the old ones off and then put the new ones on. im not sure but i think thats it. you can get them online at www.uniqueleds.com for about 37 cents a piece and if many colors.
Old Feb 13, 2011 | 07:30 PM
you mean this?
http://www.unique-leds.com/index.php...roduct_id=1731
how sure are you? also would you simply place these in, or by soldering you mean you have to desolder the old ones and the new ones, and then replace the old surface mount LED with the new one.
Old Feb 13, 2011 | 08:23 PM
jwin100's Avatar
Yes those are the lights. And it would involve desoldering the old and then soldering on the new. I'm not 100% sure that this is the case on the steering wheel controls seeing as I have not taken them off yet. I will soon this week when I change out the lights in the gauge cluster when the lights come in on Monday. I'll let you know as soon as possible thought seeing as I have a couple LEDs laying around ready to be put in the car. I'm hoping they are 0805.
Old Feb 13, 2011 | 08:28 PM
G35Papa's Avatar
Removing steering wheel
Disconnect your battery
You need to remove the airbag bolts (security torx screws) on the side of the steering wheel (under 2 little round covers on the sides of the wheel that just pop out).
Becareful removing the two plugs from the back of the airbag.
From there remove the 19mm nut off the center of steering wheel....pull it off....done
Old Feb 13, 2011 | 09:55 PM
jwin100's Avatar
sounds good. now im ready for tomorrow after work. just one step closer to completing the transition from ugly orange to cool blue.
Old Feb 13, 2011 | 10:44 PM
liljohnny's Avatar
Amber, not orange btw. You're gonna need when you drive at night cause blue will hurt your eyes after while. I have blue gauge lights in my wife's Honda and I hate them! Much prefer the amber...
Old Feb 13, 2011 | 10:49 PM
there are plenty of cars out there with blue gauges, im sure if done correctly it's just as fine as amber honestly. the color itself wont hurt your eyes, its the brightness and angle of the LEDs
