Squeaky Seat...
Old Apr 9, 2011 | 05:23 PM
rosadod's Avatar
Squeaky Seat...
Hey all... I checked out this post, but it seems to be a little different from my problem. My upper seat back is squeaking a lot when going over bumps and in turns. I plan on opening up the back of the seat tomorrow and taking a look.
Has anyone else had squeaking from the upper seat back?
Old Apr 10, 2011 | 02:43 AM
Affalterbach's Avatar
Same, although mine is overall just a bit lose feeling. Going to check out the bolts sometime soon and maybe throw some spray lube wherever I can see movement.
Old Apr 10, 2011 | 02:05 PM
rosadod's Avatar
I ended up opening the back and spraying some WD-40 around the upper metal brackets... all quite for now.
Old Apr 12, 2011 | 01:03 AM
What part exactly, I remember seeing some zippers, I think, down the back sides, did you undo those? I got some silicone lube spray at work I can use. I put it on my sun roof gasket and its quiet as well now when it slides up and open.
TheBay
Sep 3, 2015 03:27 PM
Jussaku
Jul 29, 2015 11:45 AM
cke73
Nov 27, 2003 03:35 AM
