Led strip running down the side of headlight
Old Apr 14, 2011 | 10:13 PM
newyorkg35's Avatar
Hey guys do you know how to change out the light strip running down the headlight ? I want to put some whiteish blue LEDs in it
Old Apr 15, 2011 | 10:38 AM
djfarhan's Avatar
^ dont do it
Old Apr 15, 2011 | 10:15 PM
Shiftd's Avatar
Try LEDmarkers he might be able to do something. I've heard he is good at making tails so he should do headlights also
Old Apr 15, 2011 | 11:30 PM
04G35NYC's Avatar
All these Fake Audi side strips are getting so damn played out, in NYC you see it on every type of car.
Old Apr 15, 2011 | 11:38 PM
LEDmarkers's Avatar
Yes we do it . I wouldnt say its played out on a g35 because the headlights have a clearance strip from the factory .
http://www.ledmarkers.com/Infiniti.html
Old Apr 15, 2011 | 11:55 PM
04G35NYC's Avatar
^ sorry, i wasn't saying specifically about G35. I meant i have seen so many other cars doing it, its getting played out on other cars. G35 for now it's not played out. Btw, this is Chris right with the White sick IP coupe that was repainted from DG? Do you do projector retros at all i know it doesn't say you do it i am just curious.
Old Oct 29, 2012 | 09:58 PM
blues3531's Avatar
Old thread but I have a question. The OEM side strip is out on one of my lights. How do you replace that and what kind of bulb is it? I'm prob gonna be getting 06 projectors in the next 3 months or so, so is it not worth the hassle and just leave it as it is for now?
Old Nov 13, 2012 | 01:29 PM
Texas-G's Avatar
+1 i have the same issue my driver side one is out.
Old Nov 19, 2012 | 09:40 PM
Duinit's Avatar
unfortunately you have to take the whole frontend off like you were changing a headlight. It takes a blade bulb #168. Best off changing them both out while you got it apart
Old Nov 19, 2012 | 09:45 PM
Texas-G's Avatar
is there a DIY thread on how to do it? search hasnt brought anything up
Old Nov 23, 2012 | 11:21 AM
Duinit's Avatar
It's more time consuming than it is difficult. I just had mine all apart and replaced all headlight bulbs as a HID bulb burnt out
1. pull out bottom three plastic pop rivets on inside of fenderwell
2. up on top inside of bumper there is two screws on each side to remove
3. remove all plastic pop retainers on bottom of bumper
4. remove two pop retainers that hold grill and two bolts that hold bumper on. The bumber cover should come off now.
5. Each headlight is held in place with 4 bolts, two in the front, one on the side and one on the top. Headlight assembly should come out now which will give you acess to all the bulbs.
Hope this helps you!!!
Old Nov 23, 2012 | 11:46 AM
Texas-G's Avatar
thanks alot!
Old Nov 25, 2012 | 12:21 AM
laksjd84's Avatar
why so you can look like an audi?
mike730
Jan 12, 2018 04:25 PM
bTanz
Oct 15, 2015 02:31 PM
Fireman07603
Aug 9, 2015 06:00 PM
neight
Aug 2, 2015 03:01 PM
Tylerttn
Jul 14, 2015 10:11 PM
