HID upgrade from Halogen
Old Nov 17, 2004 | 07:56 PM
Npapajohn's Avatar
I have an '03 Sedan without the HID package. How hard and is it possible to put HID on it with the packages that are on the web. Either a used setup from another G35 or a kit is what I've seen but I don't know what goes into doing it?
Old Nov 17, 2004 | 08:23 PM
G35Lin's Avatar
Multi-Spoked Mod
Re: HID upgrade from Halogen
hum...most of them are plug and play. I will be putting a set of Euro Optix on soon. I have mine on order. Top and bottom! 8k. should look very nice!
Ed
2003 Transport V35SKYLINE. Team Transport! www.teamtransport.org
Old Nov 17, 2004 | 11:19 PM
boostedinfinity's Avatar
yea you can upgrade it easily. It'll say what type of bulb u have and just get the same bulb as in a plug and play upgrade
Old Nov 18, 2004 | 01:44 PM
al503's Avatar
i upgraded my early sedan and it wasn't that difficult. It'll take about 1-3 hours depending on the tools you have at your disposal. I got my kit from hid-online.com and it was the 6000K ultinon kit. It was a night and day difference and worth every penny.
Where do you live? If in the NW, I can help you put it in.
Abbreviated Process:
1. jack up car and remove wheel (optional on the wheel but makes it much easier to work)
2. attach power cables to + battery
3. attach - ground wire to car chassis/frame
4. install ballast with zip ties and/or double sided tape to flat surface
5. attach wiring harness (+ battery and - chassis wire) to ballast.
6. attach bulb to ballast
7. drill hole into plastic cap behind the headlight assembly
8. push bulb through cap and install in headlight assembly.
Done.
It sounds a little more complex than it really is.
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
twentyeggs
Sep 11, 2015 03:58 PM
