Redoing grill
Old Jan 12, 2012 | 01:02 AM
mikenogo's Avatar
try sand paper , probably your best bet, in terms of cost
Old Jan 12, 2012 | 01:10 AM
JOKER's Avatar
CLUB MODERATOR
I painted my headlights last winter and had to strip some paint off cuz I messed it up. I used Duplicolor paint stripper and it worked fine. I just sprayed a thin layer, waited a bit for paint to bubble up and washed it away with water and brush. Re applied it in the areas where it did not remove all of the paint and repeated the process. Did not hurt the plastic one bit.
As a safety measure might wanna spray it on something plastic before you spray your grille just to make sure it will not hurt it.
Old Jan 12, 2012 | 01:12 AM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by 3pedalsdn
try goof off. it works pretty good for removing paint.
I wouldn't. Goof off is pretty strong, might melt the plastic. Paint strippers lose their effect once they get mixed up with paint that they are removing, goof off does not, it continues to dissolve things.
Old Jan 12, 2012 | 01:28 AM
Frankieg35's Avatar
I'm gonna try the duplicolor paint stripper.. thanks!!
Old Jan 12, 2012 | 02:31 PM
saywat?'s Avatar
i would imagine trying to used some paint stripper liquid would be hard then jus using sandpaper.
Old Jan 22, 2012 | 12:54 PM
JOKER's Avatar
CLUB MODERATOR
it comes in a spray can, all you do is just spray and wash away.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
Picture Share
Feb 4, 2018 12:41 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
vQFamily
Sep 30, 2015 01:17 PM
