Help! Signal lights sometimes blinking too fast!
Old Mar 3, 2012 | 06:23 PM
element590's Avatar
Question Help! Signal lights sometimes blinking too fast!
My 2003 G had xenon headlights installed before I purchased it, and the left turn signal will sometimes blink too fast on the dash but not light up on the actual turn signal lights at all, but then other times will blink slowly on the dash and on the actual turn signal lights and work just fine.
From asking around I've heard it could be because of a loose ground connection? Thanks in advance for the input!
Old Mar 4, 2012 | 02:23 AM
johnnydarko's Avatar
just change the bulb in your turn signal. more then likely its not a wiring problem.
Old Mar 4, 2012 | 02:37 AM
boyks03's Avatar
Yup. Fast blinking turn signal usually means the bulb is burnt out.
Old Mar 5, 2012 | 02:04 PM
element590's Avatar
I was thinking that too, but sometimes it works and sometimes it doesn't, so would that not be a wiring problem?
Old Mar 5, 2012 | 02:32 PM
The bulbs filament doesn't have to be broken all the way. It can still be making some contact which is why its working sometimes. With stuff like this its best to eliminate the easiest solution first
Old Mar 5, 2012 | 02:57 PM
element590's Avatar
Ah yea that makes sense. K I'll give that a try then, thanks!
Old Mar 5, 2012 | 04:35 PM
element590's Avatar
Oh forgot to mention as well, when the indicator light blinks fast and the turn signal stops working it does it for the front AND back turn signals. Would that still be a bad bulb potentially?
Old Mar 5, 2012 | 06:53 PM
GAU-8's Avatar
Yes. Filaments can break apart and reconnect with movement of the car. Check them both. Easy to get to.
Old Mar 5, 2012 | 08:02 PM
Xx AzN xX's Avatar
My signals blink fast when i put led bulbs in them. I thought it was the resistors
Old Mar 5, 2012 | 09:04 PM
GAU-8's Avatar
That's a whole different animal there. That does have something to do with the resistance in the circuit. How to fix it? I'm not the one who can help there.
Old Mar 6, 2012 | 03:58 PM
element590's Avatar
I know for the LED's they take way less power than the conventional bulbs, so you need to put in resistors to slow down the current. I don't know anything else about it other than that tho :/
As for my turn signal, I figured out that they only work if my nighttime headlights are on. If I just have the daytime running lights on they don't work. Changing back and forth between the two determines whether my turn signal works or not.
So now I'm 93% sure its a wiring problem, would it not? I don't know where to start to fix it though :/
Old Mar 6, 2012 | 05:24 PM
Hmm this is turning into quite a condundrum. Check to make sure everything on your turn signal lever works or not. I've seen something similar happen on a ford truck and it was the lever itself.
Old Mar 6, 2012 | 05:56 PM
TunerMax's Avatar
G35
THIS x10000000
The reason this happens is a little different than most people think, but in short, you need to install expensive DROP RESISTORS at each signal, or install a new LED/Digital Flasher relay (safest, most recommended option, and cheaper, AND easier) to fix it.
Well, that, or change the LED's back to stock. IMO, it's dumb to put LED's in most signal light applications anyways, as they're normally DIMMER than the stock bulbs and don't create much difference in appearance unless you go completely custom.
As I eluded to above, the traditional though on WHY LED's cause this is kind of backwards. For the heck of it:
LED's actually have HIGHER RESISTANCE than a stock bulb. To clarify, it's not the LED's themselves, but rather the built in resistors that LED's need to work. this causes a high resistance, which to the Flasher unit looks like a burnt out bulb. A burnt bulb has INFINITE (HIGH) resistance.
A normal bulb has a pretty low resistance value. because electricity takes the path of least resistance, you can fix this by putting another resistor that is close in value to a normal bulb wired IN PARALLEL with the LED bulb. This method though, causes that added resistor to get stupid hot and is somewhat dangerous, especially if you don't get the expensive ones with the built in Heat-Sink.
This is why i always recommend getting a LED flasher relay if you can do it. We're lucky and IIRC, only need the standard 3 pole relay, they can be had on Ebay for about $2 or less + shipping.
Sounds like someone's been tampering with the wiring. Take a picture of the headlights, and then another of the wiring behind them, and post it. Also, does your Marker light work?
I'd also take the bulb out if you didn't already, and replace it as already suggested. It's possible someone just put the wrong bulb in or did something wacky. We need more info.
ALSO you mentioned you have 'aftermarket' HID's. Are you sure of this, or not? Because HID's were an option from the factory on your year.
Muski_G
Dec 1, 2023 11:11 AM
deschutes606
Jul 18, 2018 09:34 PM
mtlruss
Dec 20, 2015 01:51 PM
kenthung
Jul 21, 2015 05:56 AM
Tylerttn
Jul 14, 2015 10:11 PM
