Another Driver's Side Window Problem!!
Old Sep 24, 2012 | 04:57 AM
Hieu's Avatar
your regulators are the metal guides. if they aren't bent or warped you're fine
i had a problem with my switch, when my motor went out the switch blew a solder point. i tested it by grabbing a wire and jumping that little tiny spot. it worked, i soldered it and that fixed it.
probably should have circled the spot in question.
Old Sep 27, 2012 | 11:27 AM
jrv15's Avatar
about to take my 05 G35 to dealership. window wont do anything... except when i shut it and it goes down 6 inches. then i hold up switch and pull up window.... soo annoying
Old Oct 5, 2012 | 04:58 AM
DeadCellShadix's Avatar
Im am getting ready to install my 3rd motor and this times its a brand new OEM motor that wasnt refurbished. I have cleaned the refurbished ones to a thistle but still no luck. Either the refurbs suck or something is continually burning my motors out. Getting ready to replace the regulator tomorrow. I hope you find some luck with your window! I have driven my car for 2 yrs now w/o a driver side window and im f*ckin sick of it.
Old Dec 15, 2013 | 11:46 PM
Ahmer's Avatar
Any updates on this topic??? Did the window switch solve your woes???
I too have the demon window that goes up and quickly comes back downm on "AUTO" on both the rear driver side and front drivers side windows. The Passenger side windows are perfectly fine.
Old Dec 13, 2019 | 08:42 AM
Alex.is.35's Avatar
2004 infiniti g35 coupe
Need help
Okay so I have the same issue, my window is stuck half open and it's pouring at the moment. I have gone through 3 motors already, refurbished, and a window regulator with no luck. I don't believe it's the switches because we connected the switch to the motor without the motor being connected to the regulator and the motor would start working, but when I connected it to the regulator it stops working?? Eventually my mechanic and I rolled up the window on the regulator with a ratchet but it slowly started coming down centimeters each time I closed my door until it got stuck. My friend told me to check a fuse to see if it was okay but I don't believe it's the fuse because if not the switch wouldn't work at all right? My passenger window rolls up and down just fine, even if I use the driver side switch. Please help?
browniiiz
Jan 7, 2018 02:53 PM
ceehouse
Oct 30, 2013 09:32 PM
terger
Interior
Jun 6, 2012 10:19 PM
03XG35
Jul 24, 2011 07:06 AM
ZeRo G35
Jun 7, 2011 04:09 AM
