I need help mounting aftermarket sideskirts!
Old Nov 24, 2012 | 06:08 PM
Trickstyle's Avatar
So I bought some PU replica impuls and I rushed and got em painted. so when I got them back I realized there wasn't any mounting points attached! so I've been doing my research(late, yes I know) and from what I've read, no aftermarket sides come with mounting hardware, and you have to drill holes in them or use double sided tape to keep them mounted!?!?!(https://g35driver.com/forums/interio...tion-help.html) The last thing I want is to open the door and see holes in my skirts or to have them fall off or come loose on the fwy on a hot day bc the double sided tape gave out... is there any type of mounting kit I can buy? atm I'm trying to refabricate these mounting points on the OEM skirts. or buy a bracket I can put on with JB Weld. any suggestions?
rear mounting points
middle mounting points
Old Nov 24, 2012 | 10:21 PM
alfhasg35's Avatar
U pretty much have to screw them in.. Just hope there isn't a HUGE gap u have to deal with.. Since u got the poly ones u should b okay....
Old Nov 25, 2012 | 12:49 AM
Trickstyle's Avatar
I don't want to have to resort to that, It looks cheap but if i do, I see how I can screw em in by the door sill, but what about the rear? I'm DEFINITELY not having exposed screws... I'd rather stay OEM if thats the case(which it cant be bc I've seen so many ppl with em)
Old Nov 26, 2012 | 03:47 PM
saywat?'s Avatar
would be neat if u could some how chop off the oem mount clip and incorporate it into the impuls
Old Nov 26, 2012 | 10:00 PM
Trickstyle's Avatar
Originally Posted by AmateuRN
Bought replica. Hopes it doesn't "look cheap". Lulz had.
you realize 90% of the "Impuls" out there are replicas right? If you see impuls on a G, they are most likely replicas of some sort bc ppl dont wanna pay 700+ for some sideskirts. And replicas dont always look cheap when applied properly, my VIS Kenstyle rear replica came with perfect fitment and looks great! So go troll somewhere else kid
Old Nov 26, 2012 | 10:02 PM
Trickstyle's Avatar
yeah, thats what I'm attempting to do next, I just need to make sure theres enough surface area on the oem mount for the epoxy to hold it to the skirt
Old Nov 26, 2012 | 10:30 PM
R1 Autoworks's Avatar
Former Vendor
Are they poly or fg?
Old Nov 28, 2012 | 08:59 PM
Trickstyle's Avatar
poly
jeffbdye
Jun 1, 2018 03:51 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Claudiu
Sep 26, 2015 01:04 PM
