Oem grill plastidip diy
Old Mar 27, 2013 | 01:53 PM
GeeRider35's Avatar
hey everyone i wanted to paint my grill with some plastidip and wondered if i needed to sand my grill or if it can be painted over.
as you can see on my image my grill is a bit craked and looks like the chrome is chipping?
any suggestions? is a new gril necessary? (i have a offer for 54 plastidip already)
Also, does a 03 grill fit 2004?
Old Mar 27, 2013 | 02:08 PM
JaE35's Avatar
Moderator
G35 Sedan
No need to sand just clean it of no debris. Also make sure it's a warm day out as dip hates cold weather. 03/04 grilles are the same.
Old Mar 27, 2013 | 02:23 PM
GeeRider35's Avatar
Originally Posted by jae35
no need to sand just clean it of no debris. Also make sure it's a warm day out as dip hates cold weather. 03/04 grilles are the same.
hey, did you see my photo, it looks kinda bad... Just wondering if the dip is kinda think to cover over that ruff part...
& any suggestions on which dip to use? Perfomix or dipyourcar.com?
And can this be used for my chrome handles and ect body chrome trim?
Old Mar 27, 2013 | 02:57 PM
JaE35's Avatar
Moderator
G35 Sedan
you didn't link the pic right, here you go
it may cover that if you put on enough coats..buy the dip from homedepot or lowes, those places are overpriced for nothing. It can be used on trim and handles, get on youtube and do your research. Plenty of DIY's
Old Mar 27, 2013 | 06:26 PM
GregSimmons's Avatar
I painted mine 3 weeks ago when I did my rims. Take it off, use a good degreaser, find a spot that's protected from the wind and start with a light cover coat, let it dry, then continue with the next series of coats.
I bought 5 cans and was able to paint each rim and grill with 4 coats and I had 1 1/4 cans left. And I took my rims off and painted the insides as well
Old Mar 27, 2013 | 06:31 PM
Kerry Garrison's Avatar
The smoother the original surface the better the results without having to do a real heavy set of coats on it. DipYourCar.com sells the Performix brands but at the best prices you will find anywhere. Check out the link in my sig for some of the dipping I have done, including my grill.
Old Mar 27, 2013 | 06:33 PM
d0nutboii's Avatar
like said above, make sure to:
1. do very light coating. (its ok if the first or second coat doesnt cover the surface entirely)
2. let dry.
3. repeat.
Old Mar 27, 2013 | 07:45 PM
GeeRider35's Avatar
thank you all i will try it tonight.. hopefully that crack blends in..
if not ill have to buy it dipped for $54.00 not that bad i would say..
ill post sum pics later.
Old Mar 27, 2013 | 07:56 PM
dipped my window spoiler with Gunmetal and then Silver Metalizer today
Old Mar 28, 2013 | 04:01 PM
Wi-Z_Sam's Avatar
Use a real spray paint it will last longer mine has lots of rock chips already
Old Mar 28, 2013 | 04:02 PM
^? 4-5 coats of dip should hold up extremely well. Its more pliable and should be less likely to get chips in it.
Old Mar 28, 2013 | 04:04 PM
JaE35's Avatar
Moderator
G35 Sedan
Yea dip can take a beating, lot more than what spray paint can on trim or grilles
Wi-Z_Sam's Avatar
Its like a vinyl paint basically, real paint is better
Why dont cars come plasti'd from the factory then?
I also live in wisconsin with snow, ice, its my DD
Old Apr 1, 2013 | 04:59 PM
GeeRider35's Avatar
Thumbs up came out nice.
i tried so hard to remove grill but i couldnt remove the left and right clips. i looked around and people had same issue. so i coverd everything and dipped away.
heres a picture of my grill with that crack i mentioned. Overall i liked it, and u cant notice it that much..
Old Apr 1, 2013 | 05:38 PM
saywat?'s Avatar
shoulda done it black if ur gonna go the dip route. jus looks like u tried to match it and it turned out like that
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
discoswan
Feb 24, 2016 08:57 PM
rymian
Sep 9, 2015 08:03 PM
rsingerG35
Aug 18, 2015 10:16 AM
