Custom 3rd Brake Light w/ CF Trunk - Connector Help
Old Jul 17, 2013 | 09:26 PM
WataG's Avatar
Hey guys, looking for some information on what would be the best way to install a custom 3rd brake light.
When I removed my stock trunk, with spoiler, the 3rd brake light is now gone. And there isn't one in the rear window. So I bought a cheap one off amazon just to stick there and make it legal:
Amazon.com: Car 32 LED Red Third Brake Stop Rear Light Lamp 12v: Automotive Amazon.com: Car 32 LED Red Third Brake Stop Rear Light Lamp 12v: Automotive
I'm trying to figure out where I can buy this connector:
And this is what it plugs into:
If anyone knows the name or where I can buy this connector (the male one) I'd appreciate it. I can't seem to find it on ebay, amazon, etc. so I was thinking maybe an online connector store might have one. Any info would be great, thanks fellas!
Old Jul 17, 2013 | 09:36 PM
WhosUrBuddiee's Avatar
Why do you want that one? Why not just cut it off and use a standard Delphi connector?
Delphi Packard Weatherpack 2 Pin Terminal Kit 16-14 AWG : Amazon.com : Automotive Delphi Packard Weatherpack 2 Pin Terminal Kit 16-14 AWG : Amazon.com : Automotive
Old Jul 18, 2013 | 03:57 AM
WataG's Avatar
Well I was trying not to cut the factory spoiler harness and the harness that plugs into it. Plus I'm not sure about the female part of this harness. It is wrapped in foam and tied to the trunk pop harness, so I don't know if it's together or not (as one piece/harness). I haven't looked under the foam.
Really not good with wiring so I was looking for a simple plug and play solution honestly. Let me know what you think would be best, thanks man.
Old Jul 18, 2013 | 06:41 AM
A connector is a connector. The delphis are extremely easy to install. No offense, but if you cannot do simple things on your own car, you should not own it in the first place.
Old Jul 18, 2013 | 09:34 AM
OBsessed's Avatar
Leave the connector alone all together and just t-tap the wires behind it. Use a male spade crimp on your new light to plug right in and call it a day.
Make sure you get a decent multimeter so you're tapping the right wire for +/-.
Old Jul 18, 2013 | 10:28 AM
ItsA..Gthing's Avatar
Just because you cant do something on your car, doesnt mean you cant own the car...
O.P was trying to have a plug and play set up..
Old Jul 18, 2013 | 10:40 AM
If you cannot perform simple tasks like change oil, change a tire, or connect 2 wires... then you really have no business owning a car.
Even if he did find a OEM connector, he would still have to wire it.
Old Jul 18, 2013 | 02:27 PM
WataG's Avatar
Thanks OB. Looks simple.
I'm actually very mechanically inclined and do ALL the work on my car (except the wiring, headunit). Just haven't learned electrical yet. Was just looking for a solution I could do myself instead of bugging a buddy or something. And I'm well aware how to change oil and connect two wires. But thanks for your concern!
Diode Dynamics
Accessories-Vendor
39
Nov 30, 2021 02:28 PM
g.spot
May 9, 2016 10:54 PM
G35xdriver04
Nov 7, 2015 08:31 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
