Aftermarket Headlight help.
Old Sep 16, 2013 | 11:25 PM
jthacker0066's Avatar
Unhappy Aftermarket Headlight help.
New to the website here, sorry if this is a noob question. I recently bought a 2003 G35 Sedan and I am looking to put black headlights in it but don't know what kind to get.
I have factory Xenon headlights on the 2003 G35 sedan but just wanting to get black to match my tail lights. I'm am stumped, could I use an aftermarket non-xenon (halogen with no ballast) and plug directly into the wiring harness or does the Xenon use a different wiring harness?
Any help would be greatly appreciated. Thanks in advance.
Old Sep 19, 2013 | 02:51 AM
fchdx's Avatar
Aftermarket headlights are usually frowned upon especially on this forum. What I would suggest is that if you want black headlights, crack open your factory headlights and paint them yourself. Search "paint G35 headlights" for a DIY.
Old Sep 19, 2013 | 09:27 AM
Only reason I haven't painted myself is I dread buffing the lenses inside and out. I believe that's what I'll end up doing. I do autobody for a living so I believe I can get it done without doing the search. Thanks for the reply.
Old Sep 19, 2013 | 09:56 AM
WhosUrBuddiee's Avatar
There is no decent quality aftermarket headlight. Just separate, paint, reseal. Also you only need to buff the outside.
Or search the marketplace here for a used set of projector retrofitted headlights.
Old Sep 19, 2013 | 11:15 AM
I'll have to buff the inside because one of them has a small leak around the seal and got water inside turned it yellow. What's the best stuff to reseeal with?
Old Sep 19, 2013 | 11:19 AM
Most just reused the existing butyl sealand, just reheat and press. Some add an additional bead of butyl.
http://www.theretrofitsource.com/pro...roducts_id=792
I had to polish insides of someones headlights once that had bad condensation. Easiest way is with mothers powerball and cone with some Mezerna cutting polish. Took me about 15 minutes per lens. Then wetsand and polish outside.
Old Sep 19, 2013 | 11:42 AM
Ok I sure appreciate the help, mine isn't real bad just don't suit me. My next free weekend ill probably break them down and paint them.
Old Sep 19, 2013 | 12:15 PM
JKL1031's Avatar
Are aftermarket halogen reflectors not good as OEM? If ur getting non projector, I would get some aftermarket ones and not have to worry about all the work of baking them just to have condensation issues. plus u will have a new glass surface.
Old Sep 23, 2013 | 08:43 PM
Just wanted to post a pic of how they turned out. It was fairly easy to do and saved me alot of money. Thanks for talking me out of the after markets, I am much more satisfied with the DIY and OEM.
Uploaded with ImageShack.us
Old Sep 23, 2013 | 08:46 PM
Next step is finishing up my homemade grill w/matching bumper inserts, then minor body work and I'm going to finish up by personally laying a slick paint job on it.
jilljann1
Jul 21, 2020 08:12 AM
lil beezy
Lights
Dec 23, 2015 05:25 PM
twentyeggs
Sep 11, 2015 03:58 PM
Albanian122
Sep 7, 2015 07:41 PM
