Sunroof promblem
Old Mar 5, 2014 | 01:30 PM
vashawn's Avatar
Sunroof promblem
Any here has this problem where there sun roof dropped in?
And how to fix it?
Old Mar 26, 2014 | 03:24 PM
vashawn's Avatar
Anyone with this problem!!
Old Jun 25, 2014 | 08:55 PM
evosmudge's Avatar
My sunroof dropped also early this year and is now making a lot of wind noise. I hope there is a solution to this.
Old Jun 25, 2014 | 09:22 PM
herrschaft's Avatar
The hardware that the hold up the assembly may be loosening up. You can see the mounting bracket to the right of the rail. The single bolt had fallen out on mine and I had to tighten the rest.
RF-23: http://psedog.com/cars/fsm/g35/coupe/2006/rf.pdf
EDIT: If you remove the roof: There are goldish nuts running along the side of the rail. Be careful not to adjust those too much since those are how you adjust the height of the sunroof.
Dallsinghjr1
Sep 17, 2023 11:25 AM
G35xdriver04
Nov 7, 2015 08:31 PM
NailBomb
Oct 28, 2015 07:53 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
