Change a door window on a g35x 2006
Apr 9, 2014 | 10:37 AM
Hi guys.
I need to change my front passenger window on my g35x 2006 due to a big scratches.
I was wondering if there is a DIY to do this my self. The only one i found was for the "Window Motor Replacement Procedure" and it don't show how to remove the window it self.
So if any of you had already did this before, it will be realy apreciated if you can share your experience .
Thanks !
Reply 0
Apr 9, 2014 | 01:44 PM
That gets you 90% of the way there and then you have to set the window at a certain point to take out the window bolts through access holes. It's literally that simple.
Reply 1
Apr 9, 2014 | 02:36 PM
Thanks Urbanengineer
Good i like when it's simple
Is there some adjustment to do or something like this or it's literally bolt on ?
I'll start that as soon as i receive my new window.
Thanks again !
Reply 0
Apr 9, 2014 | 02:41 PM
All windows mount up damn near the same. It's probably 2 bolts on your V36
Reply 0
Apr 9, 2014 | 05:54 PM
Good i'll let you know when i'll be working on it .
Thanks again
Reply 0
Apr 12, 2014 | 09:07 AM
You was right Urbanengineer, 2 bolts (one beind the speaker and the other is accecible buy a hole in the door)
Very easy to do thanks for your help
Reply 0
Apr 12, 2014 | 09:26 AM
Quote: You was right Urbanengineer, 2 bolts (one beind the speaker and the other is accecible buy a hole in the door) Very easy to do thanks for your help
You got it!
Reply 0
