removing bottom window molding rubber trim ? How?
Old Jul 13, 2014 | 12:51 PM
g35.silversurfer's Avatar
I've got new ones to put on but cannot get the old ones off.
I've searched and can only find this to help
http://my350z.com/forum/exterior-and...w-molding.html
I've tried pulling it out towards door handle with no luck. used some needle nose pliers and still no luck.
Really hoping it can be done without having to taking door panel and mirror off...
Old Jul 13, 2014 | 02:24 PM
hurleyguys's Avatar
just take you door panel off and see if it slides out easier. it is easy to remove the panel. a couple of screws and some clips holding it on.
Old Jul 13, 2014 | 07:39 PM
Just took door panel off, and I'll have to say, wow, it was so easy to take off.
Still cannot budge the trim piece. and I don't want to hurt the door taking it off wrong so I'm still stuck.
Old Jul 13, 2014 | 07:40 PM
It would be nice if someone with a service manual to chime in
I may just take it to nissan with the door panels off.
I also have new aluminum pedals to install, does anyone know how to take the aluminum pedals off?
Old Jul 14, 2014 | 06:38 PM
anyone?
Old Jul 16, 2014 | 07:57 PM
bump
Old Jul 19, 2014 | 11:11 AM
bump
Old Jul 20, 2014 | 04:15 PM
Frankieg35's Avatar
Take the rubber pedals off, heat up the rubber on the aluminum ones and put on your pedals..
Old Jul 22, 2014 | 08:10 PM
I already have the aluminum sport pedals. I need to take them off so I can put new
Old Jul 22, 2014 | 08:42 PM
Old Jul 23, 2014 | 07:34 PM
bump
Old Jul 25, 2014 | 08:50 PM
no one out there has ever removed this trim piece?
Old Sep 23, 2014 | 10:58 PM
dutchers's Avatar
I need to replace the cracked rubber trim pieces on bottom of all four exterior windows on my 07 G35S. Where do i get the new parts and how to replace?
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
zoop425
Mar 29, 2016 05:51 PM
linedr89
Aug 17, 2015 05:11 PM
