Plasti Dip Longevity?
Old Feb 19, 2015 | 08:29 PM
Extreme Dimensions's Avatar
It lasts a long time, I still have my emblems dipped after two years and they have gone through the car wash many times.
As far as failing, I noticed that car wax in the sun will leave spots in it, almost like oil stains.
Old Feb 28, 2015 | 03:48 PM
guitarrocker98's Avatar
Plastidip FTW
In this picture there use to be a video of it... The video got taken down by the owner..... Might have found its way back up though. What happened is the dip was put on to thin, the owed took a power washer to it. Didn't spray in a fan and it cut through the paint. Once it was through he said the heck with it I cand do more damage and kept going... This is the end result. Moron....
Okay.... Being the one on this forum that dips probably the most..... I dipped my car brown left it for about 2 years... Then I re dipped it over the brown, been like that for almost a year now. Dip holds up if your not a moron.
Now the headlight... They don't reccomendm you spray anything on your headlight... Some chemicals cause headlights to fog haze or go yellow... Different cars have different specs on headlights. Also if it's pitted sometimes you can't get the dip out of the Pitts... Then people use solvent or goo gone and ruin something.
Old Mar 1, 2015 | 11:29 AM
brycealbr's Avatar
This makes me feel a lot better Thank You.
Old Mar 2, 2015 | 03:02 AM
Your welcome... Just use common sense. Watch the videos... Over and over and over... I've seen them all so many times but it helped me out with the prepping and dipping and everything.
skippyG
Jan 25, 2016 01:18 PM
friedsqrl
18 Inch
11
Aug 9, 2015 12:41 PM
