No A/C no cold or hot air blowing out
Old Dec 7, 2018 | 07:25 PM
Dalia Fuentes's Avatar
n/a
Unhappy No A/C no cold or hot air blowing out
Hi all! I have a infinit g35 2007 About 3 months ago my a/c heater stopped working. (Doesn’t blow out any air no matter what) the defroster in the back still works. It’s starting to get cold so I’ve been trying to work on it. I changed the 2 15A fuses by the drivers side fuse box and they seem to keep blowing out. I bought a new blower motor relay, I replaced it by removing the two screws on the fuse box on the drivers side and replacing the relay closest to the floor. I think I replaced the right one. I replaced it and replaced the two 15A fuses again but still no luck. I’m stuck now pleaseeeee help! Thank you!
Old Dec 7, 2018 | 08:35 PM
cswlightning's Avatar
Well your first task is figuring out what is causing your fuses to blow up. Disconnect/cut the wires to everything related to that fuse and start plugging stuff back in until your fuse blows up. Replace that part. This will take reading the FSM and figuring out what's in that circuit.
Old Dec 9, 2018 | 12:34 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
If the fuses are blowing then something is causing the circuit to draw more power then intended, unplug the blower motor then turn the fan up on high, if it doesn't blow the fuses then something failed internally in the blower motor.
Old Dec 9, 2018 | 10:31 PM
n/a
It was the blower motor! I replaced it (literally look me 15 minutes) and replaced the two 15 fuses that kept blowing out. And Tada! My heat and ac works and IM NOT FREEZING NOMORE! Thanks everyone!
Old Dec 9, 2018 | 11:00 PM
GJ! And next time, you know where to start!
IgOtMyG
May 13, 2018 01:18 PM
Sirduke731
Aug 26, 2017 09:18 AM
k@osx71
Dec 3, 2009 07:13 PM
Deebo16
Interior
Mar 19, 2008 09:08 PM
andy2
Jun 15, 2006 04:33 PM
