05 headlight adjustment
Old Mar 9, 2005 | 09:05 PM
RxCritical's Avatar
Has anyone adjusted their 05 headlights? The descriptions for adjusting the lights on the older models don't seem to fit what I am looking at on my 05.
Thanks.
Old Mar 18, 2005 | 08:23 PM
RxCritical's Avatar
Bueller? Bueller?
Old Mar 18, 2005 | 10:08 PM
WRAH's Avatar
WRAH
Thanks.
Tee hee hee...... You prob. just have the tamper covers installed on the little holes for the adjustments
Old Mar 21, 2005 | 02:48 PM
Renegar's Avatar
The adjustments on my '05 (Jan. '05 build) are identical to my previous 2003. I swapped out my Silverstars from the '03 and adjusted the lights slightly as I did to my '03. Exact same. I use a large tip philips screwdriver to make my adjustments.
Old Mar 22, 2005 | 07:08 PM
RxCritical's Avatar
Thanks, I can adjust up and down but the other adjustment is just kicking my a$$.
Old Mar 22, 2005 | 07:19 PM
WRAH's Avatar
WRAH
I'm not sure you can get to the side-to-side? Not sure how to help? I'm going to go take a look!
Old Mar 22, 2005 | 07:27 PM
WRX2G35's Avatar
Former G35 Driver
I just checked the 05 service manual. There is only up/down adjustment, no side to side.
Old Mar 23, 2005 | 12:22 PM
RxCritical's Avatar
No side to side? Wow, that draws a vacuum! I've got my low beams where I think they should be but my high's seem to be aiming for Mars. They illuminate tree tops. And I am sure my lows are not aimed too high, I never get flashed. Maybe something for the dealer to look at and then say they are good
Old Mar 26, 2005 | 12:49 AM
supman's Avatar
hey guys..........can u guys tell me how to adjust the headlight?? cant' find any information from the service manual.
Old Mar 27, 2005 | 02:25 AM
Spottheg's Avatar
adjustment
there's a hole where the headlights are, and you use the cross screwdriver, cw will put them up i think. But when you look in the whole it looks like a plastic wheel with hinges. fit the screwdriver in, and make sure it doesn't strip the plastic, and when you turn it, the wheel should turn the same time. You could just level the driver light with the passenger, since it's standard the driver side is always lower than the passenger side.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Fox843
Nov 7, 2015 05:43 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
