Stock bumper and intercooler ventilation
Old Mar 27, 2005 | 02:52 PM
gersteinp's Avatar
I had Jeff from Avalon Racing open up a slot in my stock G35 coupe bumper to better ventilate my Vortech intercooler. Took him 10 minutes. Way cheaper than a new bumper and no clearance problems that aftermarket bumpers create.
Attached Thumbnails Stock bumper and intercooler ventilation-bumper-slot2.jpg   Stock bumper and intercooler ventilation-bumper-slot1.jpg
Old Mar 27, 2005 | 03:20 PM
BulletproofG35's Avatar
You may want to upgrade your radiator and thermostat, but if you're running stock boost you should be fine.
Old Mar 28, 2005 | 01:28 AM
gersteinp's Avatar
Stock all the way, and I live in New England (it's frickin' cold up here).
Old Mar 28, 2005 | 10:36 PM
bullseye's Avatar
We're not required to have a front tag in TN. It looks to me as if that bumper piece behind the tag comes off/out. It looks just like a blank-up piece. Is it? If so, one could remove the blank-up piece in the bumper and have a tag-size hole in the bumper directly in front of the FMIC.
Old Mar 29, 2005 | 03:41 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Paul,
I plan on doing something similar. My cut will look the same as yours when the license plate is on, but when I'm at the track, I'll reove the front license plate and the whole area under there will be open too.
a.k.a. RANDYS_G
what did you use to wrap the inside lip of the new hole?
Old Mar 29, 2005 | 06:39 PM
bzabodyn's Avatar
If I end up keeping the Nismo bumper after going F/I this fall, I'll probably do something similar (except I would make the hole line up with the other two bumper inserts) - it's definitely functional, so what else matters?!?!
Old Mar 30, 2005 | 02:03 AM
paranormal's Avatar
what about a split intercooler for the nismo bumper.. this is what i want to do..bump all this cutting the pretty bumper up
Old Mar 30, 2005 | 11:11 PM
xswl0931's Avatar
The upcoming JWT TT kit uses two smaller intercoolers to retain the stock bumper.
jsimonk
Dec 22, 2023 03:49 PM
yosip1115
Forced Induction
Jan 28, 2016 02:51 PM
yosip1115
Engine - Power Adders
12
Aug 26, 2015 08:35 AM
