Window Rattle?
Old Aug 17, 2002 | 07:47 AM
adrenalinepump's Avatar
Window Rattle?
Does anyone elses windows rattle when you open the door, or when you have them up and hit a bump? How did you fix this?
http://www.adrenalinepump.com
Old Aug 17, 2002 | 01:08 PM
Merlin's Avatar
Staff ALUMNI
Re: Window Rattle?
The rattling may not be the window or the door handle as posted before, when going over bumps or cranking up the music. It seems to be the weather strip they have placed on the lower part of the door. Try placing a piece of ordinary home weather strip on it and see if that helps to tighten the seal.
Old Aug 17, 2002 | 06:27 PM
Re: Window Rattle?
Nuck,
I think im having the same problem that you had, my problem has nothing to do with the bass of the stereo, cause it does it without the stereo on, for instance when I open and close the door, and when I roll the windows down I can hear some weird noise.. So you just tightened the bolts and your problem was solved? How do you get the doors apart?
Thanks Again!
Frank
Old Aug 17, 2002 | 06:35 PM
Re: Window Rattle?
Nuck,
Im going to shoot a email over to my dealer right now letting him know about it and that i want to have it looked at when I bring it in for my frist service.. :-)
Then they can wash it when they are done also :-) ahahh
Thanks Again!!!
G-Speed Be with you!
Old Mar 19, 2011 | 09:43 PM
dukehotty's Avatar
Bump
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
