Condensation inside headlight housing?
Anyone else getting condensation inside the headlight housing when the lights are on?
I'm only getting it on the driver's side... is this normal? bad? nothing to worry about?
and yes, i searched and found nothing.
Originally Posted by Silverbolt
You got condensation in your headlight? Damn lucky bastard! Wait a couple months, call the dealership and complain... have them replace it with an '06 projector headlight
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
There's a TSB for this. According to that document, if it's just condensation, it tells them to tell the consumer that it's normal. If the moisture starts have drops run down, then they're supposed to replace it.
The 2006 headlights may not necessarily bolt up. If they're bixenon, then you have the signal for the high beam going to the projector solenoid and/or the H4 bulb on the bottom reflector (not sure if the 2006 still will use H4 in the bottom).
magnetism80
Feb 1, 2019 10:00 AM
