DIY, removing OEM grill
1) open your hood (7 seconds)
2) pop off the 4 plastic screws on top of your grille with a flathead screw driver (about 30 seconds)
3) reach behind the grille and push up the latches and pull the grille - there are like 4 I think. (about 1 minute)
done
it's pretty intuitive once you look at it. I just did my 05 this afternoon.
done
Don't forget the two 1/4 turn bolts on either side of the grill, that you access through the upper slits (from the front) of the grill... You'll need a small to medium sized flat head screwdriver, turn them about 1/4 of a turn either direction and it'll pop out.... The rest as mentioned... If it's taking you longer than 5-10min, you're doing something wrong...
Originally Posted by cutiewolf
whoo~~i need one of these DIYs..my gill is on shipping..should be here in coupe days..if any know plz give us some trick and tips plz!!
cutiewolf are you replacing your oem grill with an aftermarket, if yes where did you get it.Please PM me I'm looking to do the same
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
yassy
Aug 9, 2015 07:31 PM
