Damn leather belt bleeding into my willow seats.
Old Sep 6, 2005 | 12:47 PM
neffster's Avatar
Angry Damn leather belt bleeding into my willow seats.
OK, what product will remove the reddish/brown dye from my leather belt from my willow seats WITHOUT removing the willow dye from the seat leather?
BTW, this was a $75 belt and I had it for ~1 year. I think the reason the dye leached into the seat was due to the extremely high temperatures the inside of my car has been seeing lately. Temp gauge says 116 when I get in my car.
Old Sep 6, 2005 | 01:07 PM
BirdMan's Avatar
Neff I had the exact same problem with my black leather belt. I tried Lexol which lightened it up a litttle but didn't do a whole lot. So , I decided to take it to a detail shop and see what they could do. The guy basically told me that in order to correct a problem such as what were dealing with, the seat would have to be re-dyed at a speciailty shop which in turn will be pretty pricey
Old Sep 6, 2005 | 01:52 PM
crypten's Avatar
I had the same problem, but with dye from a shirt of mine. I tried to lighten up the stain with a few products I had (Lexol, Griot's Interior Cleaner, Dawn), and it removed most of it, but you can still see the dye. I wouldn't be surprised if more people experienced this problem with the Willow leather seats. Any recommendations on what to use would help, cause it sucks to have dye on your seats.
Old Sep 6, 2005 | 02:00 PM
Blackjack's Avatar
Neff... PM Punchit. He's always got the right stuff for the job. Sorry to hear about the belt issue. Good Luck!
Old Sep 6, 2005 | 02:41 PM
fullofivy's Avatar
Is there leather protectant that can be applied to the seats making dye transfers easier to remove?
Old Sep 6, 2005 | 02:48 PM
Derzigster's Avatar
I know that rubbing alcohol will take out ink. You could try that but test it in a hidden area.
Old Sep 6, 2005 | 03:15 PM
TINMAN's Avatar
not sure if it works but worth give it a try.Armor All® Leather Wipes
Old Sep 6, 2005 | 05:29 PM
redwillow's Avatar
20 Year Member
it will, but it will remove the seat color too. You should try it diluted with water on a very small area.
Old Sep 7, 2005 | 08:46 AM
neffster's Avatar
I tried diluted 409 and that worked kind of well. Unfortunately my other belt now has the same problem. Maybe it's time for cloth inserts...
Old Sep 7, 2005 | 09:10 PM
uhohnumber2brb's Avatar
Wow....guess I wasnt the only one who had this happened to....but mine came off...I just rubbed it with lexol when the seat was still a hot, maybe you should let the car baked outside for a couple hours first before you try removing it....
Old Sep 7, 2005 | 09:18 PM
R8D G's Avatar
Florida G35 Club, Premier Member
I had the same problem with my dark blue jeans bleeding onto my seat. I used meguiars leather cleaner, and it took off most of the dye without harming the seat. Can't really see it anymore.
Old Sep 7, 2005 | 09:29 PM
Blackjack's Avatar
Wow.. Glad my leather is graphite. That some crazy ****.
NailBomb
Oct 28, 2015 07:53 AM
BradMD_96
Oct 6, 2015 09:31 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
TNRocker
Sep 21, 2015 08:36 AM
yosip1115
Sep 9, 2015 03:30 PM
