Grill removal on coupe?
Old Dec 16, 2005 | 08:01 PM
wickedG35's Avatar
Hey Guys,
Just picked up my SP Grill from a fellow member. Is the grill pretty easy to remove? I was searching for a DIY but didn't find one. I was told to remove the top 4 push-pins and then 2 screws from the bottom.
I haven't attempted to install it yet (will do so this weekend). Any info appreciated...
Old Dec 17, 2005 | 12:01 AM
achen's Avatar
Yea, it's really easy to take off. There are some push-screws on top and then two more screws between the bars of the grill.
Old Dec 24, 2005 | 06:52 PM
mkn1620's Avatar
https://g35driver.com/forum/showthread.php?t=75227
that website told me to : Next rotate the two side screws that are holding the grill in place. These can be located at the backside of the left and right side of the grill.
I dont see any screws in the back that hold the grill in place. can anyone show me a picture or teach me how to take off the grill please?
Old Dec 24, 2005 | 07:52 PM
CarFanatic56's Avatar
theres also some clips on the bottom of the grill that you have to get out also
Old Dec 27, 2005 | 02:27 AM
Andy2434's Avatar
I just recently replaced my '05 Coupe's OEM grill with a Gialla grill. In total in took all of 10 minutes, if that much.
1. Remove the 4 black plastic plugs on the top of grill. Save these, you will reuse them.
2. In the upper right and left corners of the OEM grill there are 2 rectangular slots. At the rear of the said slots there are 2 - 1/4" x 1/4" plastic tabs. There 2 tabs are positioned diagonally to 2 inner 1/4" x 1/4" openings. With a long flathead screwdriver, turn the 2 tabs until they are lined up with the 2 openings in the rear. Gently pull on the top of the grill and the same will slide forward.
3. Located at the very bottom of the grill there are 4 long plastic tabs, which are attached to the grill. These said tabs are secured through 4 slots, which are part of the upper bumper. Slowly and carefully pull from either right or left untill all 4 tabs have cleared the slots in the bumper.
My Gialla grill simply was re-installed using the 4 black plastic plugs, which were removed earlier. Have fun!
Old Dec 28, 2005 | 02:32 PM
c35's Avatar
c35
Thumbs up Thank you
Hi guys,
Thanks for the informative posts. I am perhaps the least mechanically inclined person on this site, and I found this info really helpful when installing my Z Sport Horns. My Andre the Giant-sized hands needed all the help possible to squeeze back there.
Thanks again and happy holidays!
Old Dec 30, 2005 | 05:14 PM
RashMan1450's Avatar
Zack ill do it for you just bring it to my house buddy
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
Frostbite91
Jul 27, 2015 05:25 AM
lemmy999
Jul 25, 2015 12:13 PM
