Grill removal
Old Feb 8, 2006 | 05:20 PM
WRXKiller's Avatar
Grill removal
how easy or hard is the front grill to remove, i was looking at taking it off an getting it powdercoated a flat black to look like the ings grill but i need to remove it an leave it at the guys shop. Any info would be much appreciated...thanks
Old Feb 8, 2006 | 05:29 PM
imalazeeass's Avatar
easy just go take a look at it, its pretty self explanatory
Old Feb 8, 2006 | 05:33 PM
RST531's Avatar
easy to remove, but u cant powdercoat the grill since its plastic.
Old Feb 8, 2006 | 05:36 PM
OOOOA3's Avatar
Alumni****
very very easy. just pop the hood, and pull it out. the ones on the ends are the hardest ones to pop out, but it doesn't take a brain surgeon
Old Feb 8, 2006 | 05:40 PM
GT-Ron's Avatar
You may be able to plate it with something, as they can chrome-plate plastic, but it's not going to be cheap. You might consider having it sprayed with a satin black paint (less glossy than semi-gloss, but not as flat as flat-black). That way, it will match the rest of your black trim on the car.
The grill is attached to the bumper with clips. The grill has prongs that slide/clip into those. Not too bad with the bumper off, but I'm not sure how much room you have to work with when it's installed.
Old Feb 8, 2006 | 06:03 PM
jonnylaw's Avatar
Sorry to hijack thread, but is it bad to clean the grill and badges w/ chrome polish since the grill is made of plastic and not chrome metal? For some stupid reason I thought the grill was chrome...
Old Feb 8, 2006 | 06:31 PM
truplay8's Avatar
THE BATMOBILE
ive heard its easy.......if you search there is a DIY somewhere on the boards.......by the way what is an ings grille???
Old Feb 8, 2006 | 06:39 PM
CarFanatic56's Avatar
removal aint bad.......
so how many WRX's have you killed....
Old Feb 8, 2006 | 07:27 PM
hye_G's Avatar
yea wtf is a ings grill, the only ones i were aware of were gialla, data systems, and oem, or the t rex billet ones
Old Feb 8, 2006 | 07:31 PM
RST531's Avatar
same here wtf is and ings grill. other grill beside the ones hye_G listed are the UT grill, and Sp grill that i can recall. ings only sort of grill insert is in the lower 2 grills.
Old Feb 8, 2006 | 07:41 PM
blazinZ's Avatar
well on the that one pic of the white cars, ing's kit, it has an oem grill thats all blacked out except for the symbol. if thats what he'd talking about. but there is no ings grill sold. i dont think at atleast.
Old Feb 9, 2006 | 12:12 AM
WRXKiller's Avatar
i wasnt sure if ings sold a grill, i was just noticing the grill on the picture in the ad at the top of the page. I was quoted for 60 bucks to paint (not powdercoat, sorry). i just think this is the best looking grill that i have seen so far, trying to get away from the chrome thing and match with the lower "air ducts" on the lower bumper. Thanks for the replys
Old Feb 9, 2006 | 12:27 AM
Andy2434's Avatar
The grill is easily removed. Simply remove the 4 round plastic pins, if you will, located at the top of the grill. Located at both the upper right hand and left hand corners, lodged inside of the grill are 2 square plastic type screws. Allign those 2 screws with the rear slot and the upper portion of the grill will be loose.
At the bottom of the grill, on the inside, are a series of long plastic tabs. These tabs are lodged into the upper bumper. Simply grab hold of the lower portion of the grill and pull it out. Good luck!
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
dcsbh1
Oct 1, 2015 03:15 PM
