Splash guard installation
Old Mar 7, 2006 | 04:57 PM
eledin's Avatar
Splash guards came in today and I'm trying to install them, but I have a question. the instructions say to use a slotted screwdriver to remove the push pin on the underside of the panel. The problem is that a slotted screwdriver won't work here, since the head is completely flat. No screwdriver fits
How do I get this off?
Old Mar 7, 2006 | 04:59 PM
louielou's Avatar
There should be a slotted groove on the washer that is underneath the push pin head.
Stick the screwdriver in there.
Old Mar 7, 2006 | 05:06 PM
eledin's Avatar
Yeah, I can get that to move around counterclockwise, but it's not undoing the screw. I'm just going in circles.
Old Mar 7, 2006 | 05:08 PM
louielou's Avatar
You are suppose to pop it out. Gently.
Push towards the pin gently and lifting it at the same time. This is not like your regular screw in which you need to turn it until it unscrews itself.
Old Mar 7, 2006 | 05:10 PM
eledin's Avatar
Forgive me for my ignorance, but how? lol
Am I prying it off by sticking the flathead underneath?
Old Mar 7, 2006 | 05:11 PM
louielou's Avatar
Push towards the pin gently and lifting it at the same time. This is not like your regular screw in which you need to turn it until it unscrews itself.<!-- / message --><!-- sig -->
Old Mar 7, 2006 | 05:12 PM
eledin's Avatar
Off to give it a try ......
Old Mar 7, 2006 | 06:18 PM
eledin's Avatar
Thanks for the help. That worked.
Got the two fronts installed. I'll do the rears tomorrow.
Old Mar 8, 2006 | 08:52 PM
eledin's Avatar
Pisser!
I didn't realize I'd have to take the wheels off to get the rear splash guards on.
Old Mar 9, 2006 | 12:26 AM
CarFanatic56's Avatar
^ can you take pics of the rear splash guard install?
Old Mar 9, 2006 | 11:22 AM
eledin's Avatar
What exactly do you want pics of? Just the different stages?
Old Mar 9, 2006 | 06:53 PM
yea, so i can see the level of difficulty of the install....im debating getting the rears or not....thanksx
Old Mar 9, 2006 | 11:12 PM
eledin's Avatar
Ok
Outside of removing the wheels, it should be just as easy as the fronts. Drill a couple holes and presto. Done.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
laksjd84
Jul 24, 2015 05:12 PM
