splash guards
Old Mar 24, 2006 | 02:43 AM
strife's Avatar
splash guards
To install the front and rear splash guards did anyone here use a ramp, or is there enough room to drill holes on the side skirt and rear bumper without ramps....thx
Old Mar 24, 2006 | 07:33 AM
daveblank's Avatar
You can do the front by just turning the wheels but for the rear they really need to be removed.
Old Mar 24, 2006 | 08:04 AM
kenchan's Avatar
this might not be relevent, but i was able to take the front and rear
off without lifting the car.
Old Mar 24, 2006 | 08:00 PM
redwillow's Avatar
20 Year Member
you don't need to remove the wheels.
you can do the fronts by jacking up the car a little. A rt angle drill and short bit would make it easier.
You can do the rears with the wheels on by using a long extension bit and drilling at an angle....but you may find it easier if you take the wheel off.
Old Mar 24, 2006 | 08:37 PM
0MGHI2U's Avatar
i just turned the wheels one at a time for the fronts and i drilled for the other holes that was needed.. Before u put u pull the adhiesve tape off make sure the body doesn't have any wax on it or the tape will just not stick at all.. for the back i just jacked it up and took one wheel off a time and made sure there was no wax on the spot that the tape was touching
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Kelvin Style006
May 23, 2016 03:47 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
st33zygill
Jul 29, 2015 10:05 PM
laksjd84
Jul 24, 2015 05:12 PM
