a/c not working after car sat for 3 months
Old Jul 14, 2006 | 09:12 PM
CubeDweller's Avatar
So my G35 was smashed by a drunk driver (see thread) - today....I got it back. FINALLY! After three months.
So here's the thing...the a/c isn't blowing cold air. I had it running for about 15 minutes and it was still wasn't cold at all. Is this going to be due to the car sitting for 3 months, or is there a bigger problem? Anything I can check for?
The car has to go back to the body shop next week to have a small part replaced, so I'll obviously be mentioning it to them then, but it's gonna be hot this weekend.
Any ideas?
Old Jul 14, 2006 | 09:13 PM
HokieZ's Avatar
You can look under the hood to see if the compressor is engaging. Depending on how you got smashed, there is a myriad of things it could be (low/high pressure sensor, bad compressor, forgot to fill it, low fill, etc.).
Old Jul 14, 2006 | 09:44 PM
Clemmdog's Avatar
Yeah, you just need to inspect it a bit... could need a re-charge, could be busted. who knows.
ExWRXDriver's Avatar
i hit a deer in my wrx, got it fixed, a/c wasnt working when i got it back... the a/c clutch was broken and the compresser wasn't engaging like he said ^^^
Old Jul 15, 2006 | 12:15 AM
upon further inspection, it sounds like the a/c compressor is not coming on at all. Crap. Crap. Crap.
Old Jul 15, 2006 | 11:48 AM
Any particular reason this was moved to the LIGHTING section?!
Old Jul 15, 2006 | 05:57 PM
jgainnm's Avatar
Was any work done inside, on your console or dash? If so, maybe they forgot to reconnect the temp sensor. If not, likely a problem with the a/c unit or an electrical issue between the controls and the unit.
Old Jul 15, 2006 | 09:48 PM
App6MT's Avatar
Littering and...
I hit a sign in my G35 and they had to replace the A/C condensor. Turns out there was a faulty gasket in it, leaked out so that would be why my A/C didn't work. They replaced it, charged it back up and works like new.
Old Jul 17, 2006 | 01:11 AM
AL ASPIRATED's Avatar
it could be anything, you have to see what was damaged cause from the accident, and what has been replaced. it can be anything from the system needing to be charged to a damged or plugged component. cant tell without at least a manifold gauge set.
good luck
Old Jul 18, 2006 | 01:58 PM
G35Lin's Avatar
Multi-Spoked Mod
where is the temp sensor inside? jgainnm ??
Ed Lin
chinee
Jun 10, 2024 07:48 PM
champppy
Mar 31, 2020 12:25 PM
apintojr
Jul 23, 2015 10:52 AM
Lsantana757
Jul 20, 2015 09:08 AM
Ninjay16
Jul 20, 2015 01:21 AM
