DIY Driver Airbag replacement w/PICS
Old Dec 14, 2008 | 08:49 PM
tom's_Z's Avatar
One more thing for this thread - if you get a dash and its a different color, you can paint it prior to installing it using Bulldog vinyl adhesive promotor and then SEM flexible coating paint - the paint, if cured properly, will NEVER come off, and looks like a stock dash.
I used this on a willow dash I painted black, used flat black paint, since the gloss black makes the dash look like hard cheap plastic.
I got my dash for $150, $770+ at the dealer new....plus tax!
Oh, by the way, instead of replacing ur clockspring, you can get the connectors from Gren2k on ebay for about $30:
http://cgi.ebay.com/ebaymotors/2003-...Q5fAccessories
Hope this helps!
Old Jan 9, 2009 | 03:34 PM
nalspeed's Avatar
how long did the whole process take you to do this?
Old Jan 9, 2009 | 07:57 PM
tom's_Z's Avatar
About 4 or 5 hours including swapping out the dash.Abercrombie333 is selling a dash.....
Old Mar 30, 2009 | 11:22 AM
prolly_jojo's Avatar
He said you just put the new airbag in, but dont you have to reset the computer and do other things in order for the airbag to function?
Old Mar 30, 2009 | 12:39 PM
tom's_Z's Avatar
You do have to reset the computer...it's right below your arm, in the center console, toward the back. Unplug it and send it to any company for resetting. Google it, there are lots of companies that do this. You also need to replace sensors for any airbags that went off.
Old Mar 31, 2009 | 09:45 PM
ok thanks a lot tom
Old Apr 14, 2009 | 10:51 AM
tom's_Z's Avatar
No prob man...
Old Apr 29, 2009 | 12:01 PM
daveatbenson's Avatar
i have a 03 drivers bag thats is burned
and i want to switch the cover off off one that was deployed,which i repaired so its not torn,
my question is ,can i just switch the cover ,with the bag unplugged,or will the non deployed bag fall out and i wont be able to get it back in place to put my repaired cover over it,this will be out of the car when i do the cover swap ,if anyone knows i really want to try this
Old Nov 24, 2009 | 10:18 PM
O HELLA OEM's Avatar
anyone in the pittsburgh/monroevilla pa area know how to do this?
i just purchased a Nissan Airbag cover, ill pay you $$$ to install my
nissan cover for me
Old Nov 25, 2009 | 12:11 AM
to the OP
are u sure u used a T25 Torx screw
and not a T30 Torx??
Old Nov 25, 2009 | 03:08 AM
HenryLee's Avatar
Nice DIY. Thanks.
Old Nov 25, 2009 | 04:03 PM
o hella , you can send me your air bag ,i will change the cover for you,if ya still need it done
Old Jan 14, 2010 | 12:46 PM
mikek46's Avatar
An opportunity to swap out the entire steering wheel!
Anyone know if a QX56 steering wheel would work for someone looking for wood trim? The electronics look identical.
Old Jun 19, 2013 | 02:33 PM
vig352006's Avatar
Thumbs up Thanks
Pics and directions worked great for me. Horn and radio controls work again.
Old Apr 16, 2015 | 07:42 PM
  #30
davidalindsey's Avatar
I think I have the same problem you had....
The Vol up button and horn does not work, I have to turn the steering wheel to the right in the right spot and the buttons work.
What do I have to replace?
Inspection is due at the end of the month and need my horn to work again..
