Door autolock and radio question
Old Sep 30, 2002 | 07:10 PM
G35EC's Avatar
Any help on these 2 questions are appreciated:
1)My car (G35 sedan) doors never lock by themselves. I have heard that it should do that after you park and leave. What do I need to do?
2)I do not notice the radio volume getting louder or quieter by itself (high setting) when driving/stopping. Any way to show that it is working?
Thanks.
Old Sep 30, 2002 | 07:40 PM
Merlin's Avatar
Staff ALUMNI
Re: Door autolock and radio question
G35EC,
You can follow this post to find out more about the door locking. https://g35driver.com/forums/showfla...sed&sb=5&part=
Basically you will find that the doors will not lock until either the lock or unlock button is pressed and no door is opened after pressing a button. The doors will then lock after a couple of minutes.
Merlin.
Old Sep 30, 2002 | 11:07 PM
nadz240's Avatar
As for the auto volume control, keep pressing the Audio button until you get to SCV and there you can adjust the sensitivity of the Speed Controlled Volume (either Low, Med, High, or Off).
Old Oct 1, 2002 | 01:51 PM
G35EC's Avatar
Hello nadz240 and Merlin,
Thanks for your responses. Regarding the auto volume adjustment due to car ambient noise, I already had the SCV at max setting. But I just do not notice any differnce at all in the volume when there is lots of road noise or when it is quiet (car stopped). I have to constantly adjust the volume manually. Do you know where the microphone that detects the ambient noise is? I suspect this feature is not working on my radio.
Old Oct 1, 2002 | 07:40 PM
ncozby's Avatar
It is not controlled by the actual ambient noise inside the car, rather it is based soley off the speed you are travelling. The radio assumes more road noise at higher speeds, and less at lower speeds and adjusts the volume level accordingly. The easiest way to notice if it is working is listen when you slow down to a stop, such as at a stop sign. You should notice the radio volume decrease slightly. However, keep in mind the feature is supposed to make the volume sound the same at all times, so you aren't really supposed to "notice" it adjusting the volume.
Old Oct 1, 2002 | 10:46 PM
nadz240's Avatar
I have noticed it working even though mine is set at Low sensitivity. I got up to 125mph once and it was really rockin!! Hey, a TL-S was taligating me and I had to show him who's boss.
Old Oct 2, 2002 | 05:02 PM
gslow's Avatar
My Lincoln LS had this feature and it was very noticeable coming off a highway exit ramp. I don't notice it at all in my G even at high setting and I too, wonder if it is working. If it is, it doesn't work as well as I would like.
Old Oct 2, 2002 | 06:00 PM
me_mike's Avatar
I didn't notice it at first (sound), but after a while I did... and now, I can always tell that its working.
https://g35driver.com/rides/detailri...x=18&vehId=130
mike730
Jan 12, 2018 04:25 PM
Frostbite91
Aug 12, 2015 05:16 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kd03g99
Jul 30, 2015 11:24 AM
