Serious Problems With Air Ventilation
Old Jul 3, 2007 | 01:09 AM
SuperShick's Avatar
Hey guys,
I've searched for this problem but I couldn't find a thing.
I just found out that my vents will blow hot air from 61 degrees+ and only blow hot air when I set the temperature at 60F. This is a must! I don't understand why it's doing this. It's 70 degrees outside and I'm setting my internal temperature to 61F and it's blowing out hot air. As soon as I bring it down 1 degree to 60F, I feel the cool air coming through the vents. WTF is going on?
Anyone have this problem before?
Thanks in advance for any help.
Old Jul 3, 2007 | 01:28 AM
jjyellow's Avatar
Did you happen to do a DD install, if so there is a wire or some sort of harness under the steering wheel somewhere that may have gotten unhooked. This would cause what you are describing
Old Jul 3, 2007 | 01:34 AM
SuperShick's Avatar
i did take apart my interior to fix a headunit problem that i was having. which harness would this be jjyellow? i've been worried sick about this so thank you for relieving me a little =)
Old Jul 3, 2007 | 01:45 AM
jjyellow's Avatar
I believe its a white harness next to the head unit, but under the panel under the steering wheel. Hope this helps
Old Jul 3, 2007 | 02:16 AM
SuperShick's Avatar
you're the man jj, that's exactly what happened. how the hell did u know that? i didn't that harness would make an impact on the climate control. what exactly does that connector do?
Old Jul 3, 2007 | 04:05 AM
cungkpham's Avatar
best guess is that it has something to do with climate control
Old Jul 3, 2007 | 05:12 AM
Jining's Avatar
I have this same problem, I had a car alarm installed. What do I need to do, just look under there for a white wire harness thats unplugged?
Old Jul 3, 2007 | 08:00 PM
jjyellow's Avatar
No prob man, glad you got it working. I just remember this problem when people first started doing dd install and were having this trouble and this came up and it stuck in my mind cause when I did my DD install I made sure not to unplug it
chinee
Jun 10, 2024 07:48 PM
champppy
Mar 31, 2020 12:25 PM
G35CO
Aug 25, 2015 02:00 PM
