airbag light blinking
Old Mar 20, 2004 | 03:07 PM
g35pimp's Avatar
I need some help with this. I took apart my dash to install something and disconnected many of the connectors under the dash, but I also made sure I connected each and everyone of them back before I was done. Now my airbag light is blinking. The dealer told me that this would not be under warranty since it was something I did and that they would charge a minimum of $95 to find out what the problem is and more if they have to do something else. I'm thinking that this problem can be fixed by simply reseting the airbag light. Anyone have any ideas how to do this?
-Noa
Old Mar 20, 2004 | 03:44 PM
Msedanman's Avatar
O.F. Administrator
Re: airbag light blinking
Try disconnecting the negative ground of the battery for 12 hrs. This may reset the blinking light... Good luck.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Mar 20, 2004 | 11:13 PM
g35mt's Avatar
there is a DIY/FAQ section that show how to reset it without diconnecting the battery. stupid as i am, i did happen trigger the airbag. i follow the procedure and it work like a charm. hope that help. Below is an exact quote i got from that thread.
"To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away. Bam! saved yourself $90
here is the url,
https://g35driver.com/forums/showfla...sed&sb=5&part=
g35mt
Old Mar 21, 2004 | 01:05 AM
g35pimp's Avatar
thanks guys. I'll try this and let you know how it goes.
Old Mar 21, 2004 | 03:16 PM
g35pimp's Avatar
IT WORKED!!!! saved some money... thanks guys.
-Noa
Luisgalvan33
Jul 19, 2018 08:16 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Jnm07
Sep 5, 2015 01:16 AM
poker_lamina
Sep 1, 2015 09:04 AM
leli_11
Aug 10, 2015 08:25 PM
