G35 glove box light always on
Old Sep 22, 2008 | 07:29 PM
trey99ek's Avatar
I have noticed this a few times and I don't know if it is normal or if it is messed up. My glove box light is on all the time, doesn't matter if the box is closed or not. I was reminded of this last night when I was driving home, I looked over and I could see the light through the seam.
Is this normal. I did a quick search and found nothing.
Old Sep 22, 2008 | 07:42 PM
jwolfpk's Avatar
im having the same problem..
Old Sep 22, 2008 | 07:48 PM
express705's Avatar
normal.
Old Sep 22, 2008 | 07:50 PM
RANC3R's Avatar
haha^^ correct
Old Sep 22, 2008 | 07:53 PM
citymunky's Avatar
If you turn your headlights on, the glove box and upper storage box (If you don't have OEM NAV) turns on also.
POST#1100
Old Sep 22, 2008 | 08:14 PM
trey99ek's Avatar
Thanks. Stupid craftsmanship. I'll live.
Old Sep 22, 2008 | 09:48 PM
DrewTheSuit's Avatar
lol, agreed...how hard is it to put a switch that depresses as you close the glovebox
Old Sep 22, 2008 | 11:23 PM
citymunky's Avatar
They want you to buy replace bulbs
Old Sep 23, 2008 | 03:34 AM
Dranom's Avatar
you need to put washers on the lock. i did it to mine and the lights turned off when the headlights are on. Its a TSB
here you go! register first so you can DL the .pdf
http://x.infinitihelp.com/forum/loca...=76&linkid=181
Old Sep 23, 2008 | 09:04 AM
lilindienplaya's Avatar
what do you mean put washers on the lock? so then there is a switch for the light to go on and off?
Old Sep 23, 2008 | 03:33 PM
Dranom's Avatar
download the file and see for yourself. The washer helps to tighten the lock so you'll get rid of the gap
Old Sep 23, 2008 | 08:12 PM
trey99ek's Avatar
Thanks, guess I'll have to go washer shopping... or just look in my spare parts can.
Old Sep 24, 2008 | 01:31 AM
Dranom's Avatar
go to an ACE hardware store. If you have one that is.
Buy the thick ones so you'll only use 2 pcs
Old Sep 24, 2008 | 09:32 AM
Infern0's Avatar
I think my refrigerator does the same thing. : /
Old Sep 24, 2008 | 10:06 AM
dofu's Avatar
20 Year Member
Thank you!
