Perforated door trim loose at top
Old Mar 22, 2009 | 10:33 PM
AVATAR77's Avatar
The perforated section of black trim on the door panels is loose at the very top, just in the middle of the panel. Anybody else experience this?
It's almost unnoticeable and it looks like I could easy fix it with a little glue of some kind (epoxy? superglue?) if I could get the glue back behind the trime. Seems like a little thing to bring it to the dealer for, but I do have about a month and change before my warranty expires.
Old Mar 22, 2009 | 10:39 PM
GreenGoblin's Avatar
The goblin resurrection
mine is all starting to come off. Time to do the interior
Old Mar 23, 2009 | 12:05 AM
darrick's Avatar
wow you 2? i was just looking at mine today
Old Mar 23, 2009 | 12:35 AM
mrfxchopper's Avatar
Mine did the same thing. I used a littel black silicone on a small flat tip scew driver to install it about 6 mo. ago. Still holding up fine.
Old Mar 23, 2009 | 01:14 AM
j 4 lD's Avatar
some of my weather stripping is coming off as well. It's the little strip between the pillar on the door and the car (kinda hard to explain). Can these be replaced?
Old Mar 23, 2009 | 02:25 PM
keen1801's Avatar
That leather section on my driver's side is coming off also. I wonder if it has to do with it being the driver's side or if they just use ****ty adhesive?
Old Mar 23, 2009 | 02:53 PM
ttrank's Avatar
Grocery getter
I have the exact same problem. Have not fixed it yet but was going to use some gorilla glue or black silicone.
AVATAR77's Avatar
Oddly enough, its on the passenger side door on mine. The driver's side is fine.
Old Mar 23, 2009 | 02:54 PM
mr_ecktid's Avatar
i have this problem too on a willow interior....i guess i need some clear silicone or something
Old May 18, 2009 | 09:26 PM
mjs0ulz's Avatar
I have the same problem with my 03 G35 sedan, passenger front door and left rear. I have the extended warranty on this vehicle and the Dealer refuses to fix it. I have wrote and sent pics to Nissan's top CEO, Carlos Ghosen and was declined the repair due to trim wear & tear. The problem is not wear & tear, but failure of the glue backing. The interior on this vehicle should last longer than 5-years!! My car is not abused and my interior is failing before my eyes!!! I believe the early 03 Models had issues with quality of materials used on the interior. Any suggestions?
Old May 18, 2009 | 09:32 PM
mjs0ulz's Avatar
Peeling Door Trim on 03 G35 Sedan
Old May 18, 2009 | 09:58 PM
AVATAR77's Avatar
I had mine fixed under warranty - had no problems with the dealer! Sorry to hear some of you guys haven't had the same luck.
Old May 19, 2009 | 09:04 AM
mjs0ulz's Avatar
Peeling Door Panels on G35 Sedan
Thank you for your follow-up. I might just try another Dealer and maybe I'll get lucky.
Danielek
Oct 7, 2015 09:59 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
dorkstar
Steering & Suspension
Sep 16, 2015 01:02 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
jbmw002
Sep 3, 2015 08:42 PM
