Passenger window goes 1/3 of the way down anytime I auto-close it
Old Jun 17, 2009 | 11:26 PM
shdowflare's Avatar
Guys,
About a month ago I noticed anytime I depress the passenger side window "up" button for two seconds (to initiate the auto-close feature), the window closes, but then always retracts (opens) about 1/3 of the way down. Is this an issue with the motor, actuator, or some other electrical component?
Thanks,
B
Old Jun 17, 2009 | 11:33 PM
tbrillz35's Avatar
Bah, this happened to me too. The window motor needs to be recalibrated, something with the motor's memory being all f***ed up..mine was under warranty and was fixed in a heartbeat. Nothing too serious!
Old Jun 17, 2009 | 11:47 PM
shdowflare's Avatar
I'm out of warranty, any idea how to re-calibrate it? I have the FSM, so I guess I can check there but figured I'd see if any fellow G35'ers know right where to go...
Old Jun 17, 2009 | 11:51 PM
tbrillz35's Avatar
eesh, can't help you there lol..Inskip Infiniti did mine for me but I'm sure one of the G-niouses out there can help..
good luck though!
Old Jun 18, 2009 | 08:21 AM
lexusk8's Avatar
The problem is that the window limit switch needs to be reset, and it's very easy to do yourself. Happened to me twice ever since I owned my G for three years. Check the discussion thread below for the procedure:
https://g35driver.com/forums/g35-sed...w+limit+switch
Old Jun 18, 2009 | 09:35 AM
Manual G's Avatar
Here's the procedure..
http://www.350z-tech.com/zwiki/Servi...eset_Procedure
Old Jun 18, 2009 | 09:50 PM
shdowflare's Avatar
You guys are awesome as usual! Thanks again...
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
mbe32
Nov 13, 2015 11:09 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
