Center Console Issues
Old Jan 15, 2010 | 12:32 AM
FlaviusFlav's Avatar
Unhappy Center Console Issues
Ok.... So I just took my console apart the other day and now I can't get the lower panel with the ashtray to properly line up with the radio panel i.e. it's crooked now. It starts off fine when I go to put it back on, but when I snap in the back near the arm rest, the driver's side drops and leaves a somewhat large gap. Can anyone help me out here? I really really want it to be lined up again.
Thanks in advance guys and girls.
Old Jan 21, 2010 | 04:14 PM
LordFappington's Avatar
Can you show us a pic? It should line up unless you messed with the tab somehow. Make sure you seat the shifter plate up to the radio panel first.
Old Jan 21, 2010 | 04:49 PM
ConradoR's Avatar
that's weird I have taken the center console off dozens of times and never had a problem. Have you check if any of the wires have moved and are now obstructing the tabs?
Do you have a 6mt or auto? Ignore this comment if you have an auto... I guess the auto is a little harder to re-install since the 6mt is just the boot, ashtray and emergency light button...
Old Jan 21, 2010 | 05:24 PM
I will post some pics later today... It is an auto, and I've tried to redo it several times, and it still doesn't quite line back up. It's only slightly off, but it is annoying.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Gip
Aug 24, 2015 05:31 PM
brane123
Aug 15, 2015 08:26 PM
Cacoepy
Aug 3, 2015 01:09 PM
