Rear Speaker Deck Vibration
Old Apr 7, 2003 | 06:39 PM
1BadG's Avatar
Hey guys I was just wondering if I was the only one who's rear speaker deck is making an awful vibration when any kind of music is playing on the coupe? Any ideas guys?
Old Apr 7, 2003 | 06:45 PM
mstil35's Avatar
Re: Rear Speaker Deck Vibration
Try installing some DYNAMAT.Should take care of the rumbling.
Old Apr 9, 2003 | 12:53 AM
pestilence's Avatar
Dynamat helps ALOT! more than words can describe
..pestilence..
Old May 5, 2003 | 02:38 AM
Ggolo's Avatar
I had the same problem. I removed the upper trunk lining (remove push pins) and found out that problem was that the rear deck was vibrating against the sheetmetal. You can fix it by just inserting a foam or a any kind soft material in between, like a shim. There's a hole right behind the trunk light that you can insert the foam in. No need for dynamats. It's a cheap and easy fix. Now I can crank really crank the bass up. Makes a ton of difference.
G35C 6MT/Ivory Pearl/Graphite/Nav/Aero
Old May 5, 2003 | 08:31 AM
johnzg35's Avatar
I too have noticed this problem. But in my case, the rattling is coming from the rear brake light. I'll have it tighted at my next service.
Old May 5, 2003 | 08:32 AM
johnzg35's Avatar
I've noticed a similar thing in my sedan. But in my case, the rattling is coming from the rear brake light. I'll have it addressed at my next service.
Old May 5, 2003 | 10:48 AM
paintballbitch's Avatar
I was thinking of Dynomat my trunk and Door, but it will add more weight to the car...
Still Thinking about it
Old May 5, 2003 | 02:56 PM
townsley's Avatar
I had a similar problem with a tinny vibration when playing loud tunes or going over rough roads at high speeds. It turns out that the defroster coil was loose. I had to whine and cry to the dealer for them to really take a close look but they found it. Now it's all quiet. The coil must live under the rear deck. The vibration sounded like a wire vibrating against metal - very specific, tinny, tight rattle.
-townsley-
2003 Brilliant Silver Premium Sedan
mjfenix
Aug 17, 2017 05:49 AM
obender66
18 Inch
Mar 13, 2016 12:20 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
Frostbite91
Aug 2, 2015 04:59 PM
