Window limit switch reset procedure
Old May 24, 2010 | 03:00 PM
the_sedan's Avatar
set the limit switch after the regulator and/or motor have been removed for any reason.....here is the procedure as per esm
1. with the door open, lift up and hold the power window switch until the door glass is fully closed.
2. get inside the vehicle and close the door.
- you need to close the door so the door switch is fully depressed
3. press and hold the reset switch. while holding the reset switch, press down and hold the power window switch until the door glass is fully opened.
4. release the reset switch. then, lift up and hold the power window switch until the door glass is fully closed.
5. open the door to release the door switch. the door glass should partially move down.
**do not use the window auto function.
**do not release the switch before the window is fully stopped
Old May 25, 2010 | 02:34 AM
TaiWG35's Avatar
where is the reset switch?
Old May 25, 2010 | 03:06 AM
DHCrocks's Avatar
its on the window motor, you need to remove the door panel and there is a black round sticker covering up the switch. it's on the metal inner door skin
Old Jul 9, 2010 | 02:04 AM
jbjwc's Avatar
Thank You it worked perfect
Old Jul 15, 2010 | 04:20 PM
A-Ram's Avatar
Thanks.
Old Aug 2, 2010 | 09:12 PM
the_sedan's Avatar
anyone that needs any other procedures....just lmk and ill post em up when i get to work and check out the esm.
Old May 23, 2013 | 08:04 PM
Mustang5L5's Avatar
Is this procedure for sedan or coupe? Are they the same
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
pasjr1972
Sep 1, 2015 10:17 PM
