WTB: Driver door window motor and both door lock actuators
Old May 7, 2011 | 08:04 PM
G3V's Avatar
G3V
My drivers side window no longer rolls up and down and both my door lock actuators are done for. Anyone have these parts they can sell to me so i can replace them myself? Thanks.
Old May 13, 2011 | 02:17 AM
pythonjosh's Avatar
FYI if you like DIY projects. You can fix everything for under $50.
https://g35driver.com/forums/interio...or-repair.html
https://g35driver.com/forums/interio...ed-thread.html
https://g35driver.com/forums/interio...uator-fix.html
Old May 13, 2011 | 05:23 AM
leoverte's Avatar
josh....need your hook up AND info for my 03 coupe....both door acts just went about a month ago...im goin to pm you as well...
Old May 13, 2011 | 02:07 PM
G3V's Avatar
G3V
Thanks josh, but where do you recommend is the cheapest place to buy a window motor/ lock actuator? I don't want a used one of course.
Old May 13, 2011 | 02:14 PM
pythonjosh's Avatar
Check the 2 lower links for the door locks, the website is www.parts-express.com search actuator and it's the only one. You will need to make your own mounting bracket tho, as described in the thread.
PM me if you want a premade kit ready for our cars.
Window motors, you can either rebuild them and replace the brushes as shown in the first link, or you can buy new from the dealer ($200/motor) or a rebuilt one (just as good really) from Autozone or somewhere. Rebuilt is better than used because they have replaced the brushes, which is the main problem with them.
I also do these as well.
Old May 16, 2011 | 12:54 PM
Yarik.G35's Avatar
eBay. But new ones are going to be expensive!
Old May 16, 2011 | 04:25 PM
pythonjosh's Avatar
Riverside Infiniti has the best prices for new window motors. They give us driver members a deal.
Rebuilding the motor is a serious pain in the azz. I did 3 this weekend, and I'm so done with dealing with them.
Now I'm just having ppl buy the motor and I'll swap it out for them. The amount of time/work involved in rebuilding it isn't worth the reimbursement.
Old Jun 15, 2011 | 02:43 PM
bor99's Avatar
My driver's door sometimes doesn't close all the way. It takes a few tries to get it to finally close. Is the door lock actuator the problem?
Old Jun 15, 2011 | 04:14 PM
G3V's Avatar
G3V
No the door actuator is for the locking mechanism, if your door doesn't shut all the way it's a different issue
Old Jun 15, 2011 | 04:26 PM
bor99's Avatar
Oh, ok. Thanks for the info.
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
