Help With Window
Help With Window
So...my window rolls down fine with the one touch feature, on the other hand when i use the one touch for rolling the window back up it will go up, and lower about 3/4 of the way down.........i was told that i need to reprogram the windows by holding the window button down for about 5 or 10 sec, and do to the same for rolling it back up. I've done this and had no luck...............Do i hold the button all the way down using the one touch feature or hold it down where I'm not using the one touch feature, same thing for the rolling up procedure.
Thanks
Thanks
If only it was that easy. You'll find the reset procedure here. Window problems are common on G's.
https://g35driver.com/forums/body-in...l-removal.html
damn.....ok....also if this happens does it mean I need a new motor soon
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
